Question about Motorola CP185 (16 Channels) Two Way Radio
Sinc won't connect to other radio on the same channel
Posted by Robbie Phillips on
unosuave
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
No RF output. Take it to a 2-way radio shop, have them check freq. and RF output.
Posted on Mar 25, 2014
I am trying to add Sirius radio on my kenwood DNX572BH MODEL. SIRRUS IS TELLING ME I NEED A RADIO ID number. I cannot locate it since the device is installed
The Radio ID can be found by tuning the radio to channel 0. It is also on the Sirius XM Connect tuner and the packaging for the XM Connect. You can directly tune the radio to a channel by pressing the Up arrow on the control screen. Next look at the bottom left corner of the screen for an icon with 3 rows and columns. Touch this icon. Enter the channel you need and press Enter. See page 68 of the manual for the DNX572BH (page 69 of the PDF). This manual is available from the support page for the Receiver: http://www.kenwood.com/usa/car/navigation_multimedia/dnx572bh/support.html?model=DNX572BH . The direct link to the manual in English is http://manual.kenwood.com/files/IM386_Ref_K_En_01.pdf .
I hope this helps.
Jun 05, 2017 | Kenwood Car Audio & Video
How can I listen to the radio without the head set?
Hi Arthur, unfortunately you can't as the wired headset acts as an antenna!
Since the FM radio uses the provided wired stereo headset as its antenna, before opening the application, connect the headset to your phone's the audio jack.
9.3.1 Opening the FM Radio
1. On the Home screen, touch
2. The first time you open FM radio, touch Auto tuning, which automatically scans for
available FM channels, saves them as presets, and plays the first FM channel
found.
May 01, 2016 | Huawei Cell Phones
How do I connect Motorola Talkabout KEM-ML36100 with Uniden pmr1188?
I don't know where you are located, but I have a feeling that you are using two incompatible systems.
The PMR (Personal Mobil Radio) is build for the European market. The allocated frequencies for it's 8 channels are from 446.00625 Mhz to 446.09375 Mhz. Your Motorola is for the US market GMRS (General Mobile Radio Service) and FRS (Family Radio Service) and it's channels are allocated from 462 Mhz and 467 Mhz area.
Bottom line is, since their channels are on different frequencies, they can't talk to each other.
BTW, it would be illegal to use the European radio in the US and visa versa. You could be interferring with other radio services.
May 30, 2014 | Uniden GMR638-2CK (22 Channels) 2-Way...
My cobra 29 lx won't go off of channel 1
what else did you do to mess up this radio.
Feb 23, 2013 | Cobra 29 LTD CB Radio
Repeats selection and won't chage seletion. superstar 3600
Obviously your channel display must be working. I would assume the radio has sustain some harsh trauma to the channel selector itself possibly a drop.
Remove the speaker side cover looking down on the channel selector and its pcb board check connection and between the mechanical switch and pcb.
This may be as simple as a cold solder joint the problem is finding it.
http://www.cbtricks.com/radios/superstar/3900/graphics/ss3900_sch.gif the schematic is for the 3900 which i believe are similar units.
Oct 24, 2011 | Radio Communications
I want to use a Motorola sport 7 radio with a Motorola T6550. What channel and code do I use?
  • Hi, the first 7 channels on both radios are standard FRS and will work together. Make sure no codes are on or they won't work until adjusted the same.
  • Frequencies for not radios according to channel
  1. 462.5625
  2. 462.5875
  3. 462.6125
  4. 462.6375
  5. 462.6625
  6. 462.6875
  7. 462.7125
  • The A,B,C channels on your sport 7 are GMRS repeater frequencies
  • A 462.5750 = Channel #16 on T - 6550
  • B 462.6250 = Channel #18 on T - 6550
  • C 462.6750 = Channel 20 on T- 6550
Hope this helps.
Regards, Tony
Oct 17, 2011 | Radio Communications
I want to use a Motorola sport 7 with a Motorola T6650. What channel and code do I use?
  1. 462.5625
  2. 462.5875
  3. 462.6125
  4. 462.6375
  5. 462.6625
  6. 462.6875
  7. 462.7125
  • Hope this helps.
Regards, Tony
My brother's PS3 on my non-HD tv. We tried connecting and getting different S-video cables but it still won't show up anything. We know the input channel is correct, it just won't show. My...
Yes the display settings need to be reset since he had HDTV and you don't. I do this by simply having the PS off then press power button and hold it for 5 seconds.
Jun 09, 2011 | Sony Playstation 3 (PS3) Console
Motorola CP185 (16 Channels) Two Way Radio Logo
46 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Jane
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
