Ovens Logo
T
Traci Posted on Mar 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code F6E8 on my jenair microwave oven - Jenn-Air Ovens
ROD GANDY
Level 3:
  • Master 1,602 Answers
  • Posted on Apr 14, 2015
ROD GANDY
Master
Level 3:
Answers
1602
Questions
0
Helped
591491
Points
4916
Go to www.ask.com /
www.about.com/
www.wikipedia.org/
what does this code mean F6E8
I have an error code on my GE Microwave JK5000DK
you probably need a new microwave or try to unplug it or you can probably take it to get someone to fix it for you
Bosch oven error code E011
My Bosch oven/microwave has error codeE 011 0 006 after cleaning with damp wipe , can I reset it ?
thanks
Yvonne
Apr 07, 2013 • Ovens
Error messages on a zanussi combi oven
What is error code F134 on Zanussi combi microwave ZKC44500XA
F84 trouble code on electrolux icon wall oven
I am getting the same error right now for the microwave part of the microwave oven combo. The oven is working fine with no racks out of place.
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
4helpful
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
F-7 ERROR CODE
sir,
check these links
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
3answers
Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
