This is a kenwood correct? this is a simple wiring all after market amps are the exact wiring there will be three posts one that probably says 12 volt, another that says either REM, or REMOTE, and another that says Ground
go and buy a amp wiring kit, it will have everything, the 12 volt post it attached to the positive of your battery post, the REM or Remote wire is attached to the blue wire with the white stripe on the back of your deck, NOTE! if you have a stock radio you need to get the wiring diagram for your wire harness if you need this let me know ill help you get it, and the ground goes within 6 inches away from the amp attached to bare metal on the body of your car. grind off the paint of possible, make it a good solid ground.
Http://www.retrevo.com/support/Kenwood-KAC-622-Amps-manual/id/479bh233/t/2/
i would like to know how to id the pins on a kenwood kac-622 since i dont have the wiring harness and the wiring manual dont id the pins.
