Question about Nikon D3100 Digital Camera
Autoexposure error when i start my cam i found an error in my nikon D3100 showing autoexpore error please contact nikon service centre
Posted by Sanjay Thacker on
TC CAMERA REPAIR.Com
  • 176 Answers
Needs a new aperture base plate, Can only be put in by camera repair person, Major work, At least $ 145.00
Posted on Mar 07, 2014
3 Related Answers
John Cunningham
  • 6771 Answers
SOURCE: nikon d3100 showing no sd card inserted message even after inserting it..please help
The only thing I can think of remove the SD Card, start camera, and go into the menu, check to make sure there are no pictures on the internal memory, if there are! erase them and restart camera and power off, re-install card and hopefully you are good to go. If no change! have the camera shop run a quick check.
Posted on Mar 24, 2012
Rider On Way
ONE-Touch-Solution
  • 1679 Answers
SOURCE: Hi My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? please help me, it's an emergency. Thanks!
This should be helpful.
Turn the lens to Manual mode (moving to M). Twist the very tip of the lens till it unlocks.
If you twist the lens on the end far enough on the end to the right you will find it "locks". This is what is causing the screeching sound,, it's locked and can't auto focus. Twist the very end to the left till it releases. This fixed it for me.
Regards,
Sean
Posted on Jun 09, 2013
Art Scott
  • 357 Answers
SOURCE: Hi My Nikon D5100 camera giving a sin of Autoexposure error. Contact a Nikon authorized representative message after it's drooped from my tripod on the deck floor (Wooden Floor). The Nikon55-300mm
There is no way to really answer this question as the camera was dropped. If it was dropped with the lens, then the problem could be either in the body or the lens (or both). If you have another lens try it and see if you get the same result. Otherwise you are probably going to have to take it to the shop or send it to Nikon
Jerking motion
Try switching of the camera. Remove the lens and check if al contacts are in good order (no dents), clean and shiny if they look good to you, replace the lens and switch on the camera. If the error returns, the best thing you can do is is late the error, by placing another lens. If you don't have on. take the camera to a camera store and ask there if you can try another lens.
Then when you are sure where the error is, bring that part to the Nikon service centre, Or when it is the lens, buy a new one. The standard lens (or even the 18 - 105mm) are not that expensive.
Success
Feb 09, 2014 | Nikon D3100 Digital Camera
Jun 09, 2013 | Nikon D5100 Digital Camera
Replacing a LCD screen Nikon D3100 How to do it?
hello, to disassembly the nikon d3100 and change the lcd you need the disassembly instructions and pictures i had found a official service manual that has them and it will help you with that ,you can download it from the below link:
http://goo.gl/AvZHV
Good Luck
May 19, 2013 | Nikon D3100 Digital Camera
D3100 service manual
Hello, i had found a official service manual for nikon d3100 that is very hepful you can download it from the below link:
http://goo.gl/AvZHV
Good Luck
Mar 22, 2013 | Nikon D3100 Digital Camera
My nikon d3100 live view lcd screen wont come on. takes pics just cant review them or open menu
Hello, try to factory reset it, if still does not work and you will need to disassembly your nikon d3100 and change any parts i had found a official service manual that it will help, ypu can download it from the below link:
http://goo.gl/AvZHV
Good Luck
Feb 23, 2013 | Nikon D3100 Digital Camera
Nikon D5100 Autoexposure error when camer is first turned on
Hi I'm having the same problem!!!
My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? I tried few does not work, please help me, it's an emergency. Thanks!
Aug 28, 2012 | Nikon D5100 Digital SLR Camera With...
My nikon D3100 got wet from rain...what will i do?
Remove the battery imediately, the memory card and the lens. Place the camera body, lens and memory card in a warm dry and place for several days to dry out completely.
When the camers is dry, insert the battery, lens and memory card, turn on the camers and set the date and time.
If the camers does not work charge the battery and try again.
If it still does not work then you need to send it to the Nikon service centre for repair.
Jan 15, 2012 | Nikon D3100 Digital Camera
Nikon service centres in bangalore india
NIKON SERVICE CENTRE IS AT MATA ELECTRONICS, SP RD,NO 86,1ST FLOOR,OPP TO ANKIT INFOTECK.CONTACT MR VIJAY. 9035871324 .080-22130711. BEST SERVICE.
Jun 27, 2008 | Cameras
Nikon D3100 Digital Camera Logo
128 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
