Question about Samsung Galaxy Reverb
Wrong voicemail number
My voicemail number is different than my phone number, leaving me unable to check my voicemail. How can I change my voicemail number?
Posted by Fd Up on
Elena Gillbert
  • 4 Answers
Hi....
Has anyone ever received a personalized voicemail message from a wrongnumber? It happened to my mother a few years ago. A woman greeted her by name and then went on to say some encouraging words. My mom did not know this woman. Tonight I received a message from a man who said my name, asked how I am doing, and then said we would talk soon. These people obviously misdialed, but what I don't understand is why they leave a message and even say the other peorson's name.
you can take the more information then click herehttps://klantenservicenederland.co/microsoft/
Posted on Jun 30, 2020
Charles Gelder
    New Friend:
Not helpful
Posted on Aug 12, 2015
Recu Daniel
    New Friend:
  • 7 Answers
Call your services of the number company you have(like T-mobile).
And they will help you with that problem.
Posted on Mar 07, 2014
Our school has a Siemens 500 OptiPoint 500 advance phone that has a greeting one. Can't find out in any of the manuals as to how I can go about changing it. Can anyone out there help me?
We always programme the voicemail to 555. If you have something different change what is below, which is our 'one sheet' user guide from www.dschiltern.co.uk
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
Sep 17, 2014 | Siemens optiPoint 500 Advance - Corded...
How do i change my voicemail number?
Press phone/menu/settings. Is the speed dial for your voicemail showing correct in there? If so, and you are still reaching the wrong number, contact sprint and explain to them what's happening. It's possible your default vmail number has gone a little screwy in the number change.
the place to check your speed dial is phone/menu/speed dial.
Apr 27, 2014 | Blu Zoey T176 Unlocked GSM Dual-SIM Cell...
How to check voicemail messages
I assume you mean voicemail messages taken by voicemail service on your telephone line, the ones indicated by a flashing "voicemail" indicator on the phone. You may need to contact your service provider as not all systems are the same, but here's how it usually works. From your home phone, dial your own number so that the voicemail answers. Press the "*" button and you'll be prompted to enter your passcode. (The default passcode is usually the last 4 digits of your phone number, and you enter a new one when you go through mailbox setup.) Once you've entered the passcode and are in the voicemail system, voice prompts guide you through how to access messages and make setup changes. To process is usually the same to check your messages when you're away, although some service providers may give you a different access number to call. Again, check with your service provider for all the details if your system is different.
Sep 14, 2011 | Vtech 5.8GHz Analog Cordless Phone
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Trying to listen to voicemail grettings.
If your talking about listening to the individual mailbox greetings without calling into the system then you could use feature 980 (leave message)
enter in the mailbox number you want to check and press ok.
Jul 09, 2010 | NorStar M7310 Corded Phone
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Nov 08, 2009 | Uniden Cordless Phone
    Voicemail Malfunction
    If you are using a different phone and using the press and hold 1 for voicemail dial the new phone might have the wrong number programmed. Dial your actual number from your phone (call yourself) and see if it works
    Jan 09, 2009 | Motorola Mobility RAZR V3
    Voicemail answering
    Contact your mobile service provider's helpdesk for further assistance on activating your VM
    Aug 28, 2008 | Motorola Mobility RAZR V3
    Razor v3 voicemail
    Changing the voicemail message would entirely depend on your provider - how they set it up for you and how you can setup your own message. They must have a specific number you can dial to set your voicemail message. This setting is not available on your phone; rather voicemail messages on the voicemail server of your provider. So, the best way out would be contact the provider. Cheers
    May 10, 2007 | Motorola Mobility RAZR V3
    Samsung Galaxy Reverb Logo
    129 people viewed this question
    Top Samsung Cell Phones Experts
    Muntejaya Ginting
    Muntejaya Ginting
    John Tripp
    John Tripp
    Ekse
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
