Question about Xantrex Technology Heart Freedom 25 Inverter/Charger 12v, 2500w 130a, 81-2511-12
My xantrex make a continued soud and show f08
This arrives after pluging a demolitionn drill on it
110v been pluged into 240v so does not work.solutions
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 11, 2014 | Makita DC18RA Rapid Battery Charger For...
My charger for cordless 12 v hitachi drill got wet without realising pluged it into power point it went pop. Is it worth or at all possible to repair
It will not be repairable as the electronics will be burnt.. Try e-bay for a replacement or get a charger from a dealer or on line from the manufacturer themselves
Jul 23, 2013 | Drills
How to replace power cord
REMOVE SCREWS IN DRILL WHOLE UNIT OR JUST HANDLE WILL SPLIT IN HALF INSIDE YOU WILL SEE YOUR WIRES PLUGED IN OR SCREWED IN . PUSH ON STKONS MYBE ON WIRE ENDS IF YOU CAN REPLACE THEM GREAT.IF NOT JUST STRIP BACK WIRES AN WRAPE AROUND SCREWS AN SCREW IN TITE REPLACING WIRES GREEN TO GREEN RED TO RED BLACK TO BLACK & WHITE TO WHITE SCREW UNIT BACK TOGETHER AN DRILL
Aug 30, 2012 | Makita & 1/2 Inch Drill
I got a set of 1985 yamaha virago 700cc carbs to look at and clean, was having a flooding problem from one, i found nothing wrong with floats, i did find that one of the float bowls had a pluged up vent...
Hi, Rondog138 the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha XV535 Owners Workshop Manual
OEM parts for Yamaha
YAMAHA XV535 Owner Manual
Yamaha XV 750 Virago 1985
Yamaha Virago Wikipedia
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 02, 2011 | Yamaha Motorcycles
My car is not wanting to go. I give it gas and its not going very fast and it rams up
check your catalitic converter it may be pluged, a simple test ys to raise the car on jack stands and use a small drill bit or a self drilling screw to make a hole in front and rear close to converter, start up your car and feel air coming off both litlle holes it must be equally, if you have lots of press from front hole (closes to engine) there you have it your cat is pluged. use same screws to plug holes test done. good luck
Feb 03, 2011 | 1999 Saturn SL
My dewalt drill charger started smoking when i put the battery in although it wasn't even pluged in to the wall and now won't work
If this is for the 14 and 18 volt batteries, this is what I found had occured on one model I repaired (I've forgotten the charger model number):
It had a shorted diode (the bad one had obvious burn marks on the pc
board). I used an NTE 5809 diode to replace the original one. BTW you'll need
a Tamperproof Torx T-10 to open the case to access the pc board.
Feb 10, 2010 | Dewalt Drills
Had this battery on charger for months. removed it pluged it into drill and it started getting hot.removed from drill, heat reached 138 degrees before subsiding. this is the second time the same thing...
the battery is supposed to be removed from the charger as soon as fully charged ,otherwise it will cause the battery to malfunction and eventually die
Nov 14, 2009 | Drills
BC430 Charger burns fuse with no batteery pluged in
the charger has a direct short in the board and you would need to either find it e.g. cord, burnt circuit or replace the charger. It would be best to replace it.
Oct 06, 2009 | Bosch Drills
When batteries are pluged in lights do not light up to show charge
Then unfortunatly your battery charger is faulty and has to be replaced. If the unit is under warranty a Ryobi service center will be able to supply on free of charge.
Apr 15, 2009 | Ryobi Multi-Volt Battery Charger
Xantrex Technology Heart Freedom 25 Inverter/Charger 12v, 2500w 130a, 81-2511-12 Logo
Top Xantrex Technology Boating Experts
ray gallant
Dariusz Zalewski
Dariusz Zalewski
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
