Sony PlayStation 2 (PS2) Console Logo
Question about Sony PlayStation 2 (PS2) Console
Remove parental controls PS2 brick
I would like to reset parental control settings on my ps2 console
anonymuswere
    New Friend:
  • 26 Answers
Enter 7444 in the parental controlls password box to reset the password and controll levels
Posted on Dec 05, 2014
5 Related Answers
Anonymous
  • 133 Answers
SOURCE: Parental Control Feature on the PS2
3 answers for the price of one. Start a DVD, bring up the menu with select, and then go to Setup. It's in there. To get it to actually save, eject and take out the DVD (kicking it back to the setup screen) before you turn the power off when you are watching any dvd, hit select on the controller to bring up the onscreen menu. on the menu, under the number 7, there is a icon called setup. click it. hit right on the digital pad (on the controller) two times and you will be at custom setup. now, go down to the parental controll part and set it up to your liking. While in the "custom settings/parental control" options press SELECT and enter the 4-digit number "7444" whenever the parental control display asks you for your password. the old password will then be deleted.
Posted on Jul 31, 2007
Anonymous
  • 709 Answers
SOURCE: changing parental control
Start the PS2 up and load the DVD. When it shows the Parental screen select YES. When the Password box pops up. Press the Select button on the controller. Type in 7444. Then your password is reset. It will ask you to enter another password. Do that twice. Allow the movie to start. When it gets going pause the movie, Press the Select button on your controller again. The DVD menu pops up. highlight SETUP. When that setup screen appears go to the 3rd icon from the left. Press X. Then highlight Parental Code. Set the parental lockout level to OFF.
Posted on Nov 20, 2007
Anonymous
  • 12 Answers
SOURCE: ps2 slimline parental control code
try this
  1. Bring up the screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings
Posted on Dec 27, 2007
Anonymous
  • 152 Answers
SOURCE: My PS2 controller port stopped working!
Sounds as if it has been dropped .....or an impact to the controller port while one was plugged in. in some cases the in side of the port can become full of dust and dirt causing light rusting creating a loss of connection ...but an impact can break a small chip on the back of the controller port inside the machine , try cleaning out the controller port and check to make sure the metal tabs are clean and un bent.
Posted on Nov 19, 2008
Anonymous
SOURCE: need to change the parental control password
press select on your controller and then enter password 7444 this will delete current password and allow you to set a new one...
Posted on Jan 02, 2009
1helpful
How to reset password on playstation 2
Hi Jessica
There are two methods to reset the Parental Control on a PlayStation 2, the Quick Method and the Easy Method.
The Quick Method to Reset Parental Control
  • Power on the PS2
  • Press the Reset button
  • Inset an R-rated and wait until the board comes up telling you that Parental Control is on
  • Hit the Select button
  • At the enter password prompt, hit the Select button
  • At the Delete password prompt, enter in your password
  • Hit the X button
If you do not know the Parental Control password on your Ps2, try the known defaults of 1111 and 7444.
The Easy Method to Reset Parental Control
  • Unplug the PS2
  • Wait approximately 72 hours
Hope this helps :)
Have a playstation 2 is set on level 8 parental and i have been unable to reset parental controls to watch movies
Just go into your settings and select parental controls. You will have to insert the password and then you should be able to change the setting no problem.
1helpful
Forgot my parental code for my ps2 how can i
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under GA_googleFillSlot("TL-IMU-Article"); custom setup.
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
How do you change a paratonal control on ps2
  • unplug the ps2, wait 72 hours or.. Power on the PS2
  • Inset an R-rated DVD and wait until the board comes up telling you that parental controll is on
  • Hit the X button
also if your parents never set one the defualt codes are 1111 and 7444.
I bought a used ps2 and it had a parental control code so i can;t watch movies at all
7444 is the password reset for PS2 parental control. Enter that and you should be prompted for a new password.
3helpful
How do you take off parental control on a ps2
Courtesy of Yahoo Answers:
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
Parental control
hi crakmonk
At the screen where it ask you to imput the password enter 7444. the old password will be deleted and you will have to setup an new one.
Just leave it blank to not have a password setup.
or look here for more info Open Tech Support - Playstation 2 Parental Control Reset/Bypass
riz.
Parental control ps2
The Ps2's parental control is always on, but it depends what level it is set at. Here is a good tip....put a normal dvd in it and you should see a thing pop up and say that it needs to change your parental controls. then type in the password ex:0000 or whatever you put in or you can just do all 0's
Ps2 parental control
You may want to try "5432" when you have to enter the code (not to delete the code, but where it asks you to enter it when you insert a movie). My friend had the same problem, and that's the code we used (after an hour of entering random numbers) to get past the parental control lock.
2helpful
Changing parental control
Top Sony Video Game Consoles & Games Experts
Marvin
Marvin
ELECTRICKSUSA
ELECTRICKSUSA
Steven Wander
Steven Wander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
