I just called protocol and they sent me one free cause i only had it a couple of wks. before it went bad. They can get them though its not on the parts listI just called protocol and they sent me one free cause i only had it a couple of wks. before it went bad. They can get them though its not on the parts list
You can't post conmments that contain an email address.
adjust the trim on the controller please watch some beginners videos. In this instance the problem is yaw which is left and right rotation on a helicopter it is affected by the speed of rotation of the tail rotor relative to the speed of main rotor and its gyroscopic effect. the floor cause weird flight effects on helicopters to get the trim precisely set it must be at least 4ft from the ground. but initially just get it to where it is controllable.
the black wire is a ground connection follow the power till you see the -
+ - follow the minus sign till you reach near the red wire that goes to the tail motor and solder it or even next to the power - whtch ts the ground part
you can try amazon, but if your tail rotor is not spinning you should take off the canopy and make sure the leads are well connected,and if they are then get your self a new PCB Board,and if you just purchased it just return it, but if you had it for a while then follow the steps above good luck...
