Question about Dual Electronics CECT P168 Cellular Phone
I168 not working with AT&T service
My new I-168 cell phone is not working wity AT&T service
Posted by cclieutenant on
Anonymous
  • 32 Answers
***First Step***
1.Main menu --> Select Service
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Posted on Jun 25, 2009
.how do i unlock motorola c168i from network pin block
you can unlock your motorola i168 using codes. you can get the codes from Onlinegsmunlock.com
Feb 01, 2012 | Motorola Mobility C168i Cellular Phone
My nokia c3-168 mobile is locked i want 2 unlock plz give me the restriction code of nokia c3-168
Only Nokia C3,not C3-168,you specified 168 for what?It's simple to Unlock the Phone from the restriction lock,You can get the restriction code from here
Theunlockspot and Unlock it,Check code for Your Network Lock,Country..
Jun 26, 2011 | Nokia C3 Cell Phone
Je n arrive pas a restaurer mon iphone j ai toujours une erreur 1015 qui s affiche
Télécharger
http://modmyi.com/forums/3g-s-downgrading/714717-ultimate-downgrade-tutorial.html
puis
Après la deuxième restauration ne sont pas utiliser de la neigerouge, utilisez la pluie pourpre. Purple rain sera roboot votretéléphone sans utiliser irecover ou QuickPwn. après jailbreak estyoull complète être bloqué en mode de récupération suffit de débrancher et rebrancher ouvrez iTunes. iTunes devrait rocognizevotre appareil et activer votre service
Bruce
Jan 12, 2011 | Apple iPhone 3G Black Smartphone
Ú?Ú¯Ù?Ù?Ù? Ù?فÙ? ساÙ?سÙ?Ù?Ú¯ را بشکÙ
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Jan 04, 2011 | Cell Phones
Bloqued nokia 5800 at turnig it on
upgrade ur phones firmware and also format ur phone.. new upgraded firmware will surely help u
Aug 14, 2009 | Nokia 5800 XpressMusic Smartphone
I need to download a manual for a new ph i brought its a Imden i168 smartphone, were can i get this
i can not finde this driver : IMDEN i168 china mobile for windows xp (usb)
Jun 21, 2009 | Cell Phones
My new i168 chaina mob touch screen not working how can I solve the problem. I can not dial the nos.
keep tapping the screen until you see the setting screen and tap above the pen setting until you get the pen setting to get it to work. it took me all day to tap on the screen until i got to pen setting to get phone back to working
Jan 03, 2009 | Nokia N95 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
232 people viewed this question
Top Dual Cell Phones Experts
William Alequin
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
