Question about UTStarcom CDM8630 Cellular Phone
How to setup voicemail box on CDM8630 UTStarcom
How do I change voicemail setup?
Login to you voicemail and listen to the prompts
Jul 23, 2013 | Mitel 5330e IP Phone 50006476
When I transfer a call from the front desk, the person's voicemail does not pick up, it transfers back to front desk.
Either the voicemail box isn't setup, the voicemail box isn't assigned to that extension, or that extension has forwarding setup that is incorrect. I have no experience with a Nortel phone system though so if you need specifics on how to get into those areas of your system to fix them you'll have to wait for another response.
Jun 09, 2011 | Nortel Networks T7100 Corded Phone
Trying to setup voice mail for my LG 900G (same as the GW300). I press "1" as instructed and it asks "if I have a voice mail box for this customer." I do not yet have a box and need...
If people are able to call your voicemail try calling your own number pressing star and entering your password if people are not able to setup voicemail call your carrier and make sure they show that voicemail is added
Jan 14, 2011 | LG Vu Cellular Phone
How do you perform a master reset?
go to phone options then security ad irt is n there
May 17, 2010 | UTStarcom CDM8630 Cellular Phone
Utstarcom um100c modem drivers for windows 7
1. Start the install process as normal, you will get to the section that asks you to plug in the um100c.
Windows will not automatically install these drivers for you.
2. Leave the setup program running and open up Device Manager
3. Find UTStarcom UM100C under unknown devices.
4. Manually search for the driver in "C:\Program Files (x86)\Cricket\QuickLink Mobile\System\driver".
After it installs there will be two more unknown devices in Device Manager. Repeat the manual driver lookup in the same location to install them.
5. After that go back to the setup program, you should now be able to click on Next to finish it.
Jan 01, 2010 | Computers & Internet
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
How do i change the number of rings on my phone before it goes to voicemail
The change is made in the voicemail system, not the phone. Get in to your voicemail box, listen to the menu and select the option for 'setup', 'settings' or 'system options', the exact name varies according the voicemail system, and you usually have to make several choices, but the options are almost always availble with menu selections. With hundreds of voicemail systems available, that's about the best advice you'll get with the information you provided.
Jul 21, 2009 | Lands Phones
UTStarcom CDM8630 Cellular Phone Logo
56 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
L Vincent Testa
L Vincent Testa
Andrew Taylor
Andrew Taylor
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
