Question about Toshiba 1GB USB 2.0 High-Speed Flash Drive 1 GB USB Portable (PA1399U1MEMFT) Drive
Usb flash drive
Got a toshiba 1.0gb  flash drive and it did not have any instructions with I do not know how to use it. Can you please help me
Posted by cateyesgw on
  • phoenixwings Sep 12, 2008
    I have a flash drive that registers on my computer but shows up empty when I open it. It works fine with other computers. Just my Windows XP doesn't register that theres anything there.
Lyle Siemens
  • 328 Answers
It is simple to use, simply plug it into a working USB port on your computer and Windows or Mac will detect it as an external drive device. You will find the new drive under My Computer. The bottom right may display a "found new hardware" or something similar. Once you find your drive, open it and choose what you want to put on it. Just drag everything you need onto the new drive. There is a possibility that you have to format it first. Do do that, just right click on the drive device and choose Format. Use FAT or FAT 32. To remove the USB drive, find Safely Remove Hardware close to the time, right click it and select remove. This is more important on a MAC because data could easily get erased if removed without giving instruction to remove it.
Posted on Oct 29, 2007
Anonymous
    New Friend:
How to remove files from flash?
Posted on Dec 08, 2009
mimahoch
    New Friend:
I can not remove files from my flash drive. error 35 comes up.What do I have to do?
Posted on Jun 09, 2011
Hack Crossfire
Help me please , My USB Toshiba 8GB show only 4MB
Oct 26, 2011 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
I want to remove the flash drive from my laptop and i cant find the icon that says safe to remove the unit? dont know what i touched and cant find the icon anymore. please help
All you are required to do is to shut off the computer and then remove the Flash drive. Ned not wait for the icon or any other instructions.
Mar 29, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a Toshiba USB flash dive with a plastic type of cover over the flash drive, how do I open it?
We just figured it out. Pull the end of the black plastic side and it slides out. It would be great if there were some instructions. Hope this helps!
Oct 14, 2010 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
I have toshiba USB 2.0 flash drive USB-4GTR. I
I would open the drive via My Computer, and copy the files to a folder of your choice (like My Documents -> My Music for example), and then attempt to point WMPlayer to this folder.
Nov 14, 2009 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Problem in usb flash drive
it is possible that the flah drive is damaged, try flashing it with a pheonix util, or take it back cos it should be under warrenty
Oct 08, 2009 | Toshiba Margi Compact Flash...
How do I Transfer Data from computer to Flash drive
Please click here for a list of how-to links that will help you accomplish this task
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 13, 2009 | PNY IronKey 4GB USB 2.0 Flash Drive
Flashing LED light but not working
Unfortuntly, this caused the drives power source to be exceded and damage the drive or circut board. If you know someone that knows computer well, have them or yourself take the hard drive out and manually connect the driver to a computer and extract your data, if the drive is not damage that is, there is know way to know for sure until you try to connect to a PC directly. Or, purchas another USB external housing.
Feb 11, 2009 | Toshiba 120GB USB 2.0 Portable External...
Usb memory stick
If the old computer is running XP.. then patch it up with service pack 2 and then transfer the files!
Most often service pack does the job.. Also the transfer is fast with the SP2 installed
Apr 08, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Toshiba USB Flash Memory U2J-001GT(A)
Just right click onfiles that you want to transfer and copy them.Than double click on the icon for the flash drive under my computer and once you are inside the drive just paste is over there.thts all you need to do.
Dec 30, 2007 | Iomega 1GB Micro Mini USB Drive Flash...
Computers & Internet Logo
384 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
