Question about Life Fitness F1 Smart Treadmill
Reset button keeps coming on 5500TR treadmill
The treadmill stops
Incline stuck at 12
please follow this steps and fix it. Merry Christmas
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 18, 2013 | Nordic Track NordicTrack - E 7.5
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Dec 17, 2013 | Exercise & Fitness
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
·3
Dec 09, 2013 | Horizon T203 Treadmill
Mohamed1324
reset the machine use the small button to the side of power button and proceed according. God bless you
    • 3
    • 4
    • 2
Dec 02, 2013 | Exercise & Fitness
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Nov 13, 2013 | Cadence Exercise & Fitness
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
After attaching key all lighs come on but none of the buttons work except foe pulse feature. also belt won't move.
rests the treadmills, follow this steps and fix it. God bless you
replace old batteries ( if your system has batteries, clean the contacts batteries from oxide, dirty, etc) put a new one. Tight the ribbon cable inside the display board+tight the upper and lower connector too.
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track C2255 Console (treadmill)
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
Factory reset code
follow this instruction and reset. God bless you
need replacing, or move on to the next step.
  • 2
    treadmill.
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2Z4hlSTfH
    Jul 15, 2013 | Landice L7 LTD Executive Trainer Treadmill
    PLO5 error message on Quinton Clubtrack treadmill
    Try to clear the error message. God bless you
    • 2
    • 3
    Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
    Life Fitness F1 Smart Treadmill Logo
    Top Life Fitness Exercise & Fitness Experts
    Vincent G
    Vincent G
    Thomas Perkins
    Thomas Perkins
    Marvin
    Marvin
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
