Galaxy Radios DX-99V 40-Channels Base CB Radio Logo
Question about Galaxy Radios DX-99V 40-Channels Base CB Radio
I have dx99 it works good when it works you can put your finger on the board inside and it works what mite be my problem
Mike Charette
    Genius:
  • Galaxy Radios Master
  • 1,847 Answers
You have a crack in the pcb board.
Posted on Aug 09, 2014
MSI P45 NEO Board does nothing when power1 is pluged in shows only a few red lights when its unplug from power1 there's power but no display
go to www.youtube.com/how_to_setup_front_panel_connectors
you mite have to re range the wording to get the front panel light setup
you mite have to use motherboard type, various type of word and to the point but they will be able to help you resovle the issue
ps if the photo on the screen diplay is correct, the words mite be on the motherboard, it mite be abbrivated but just remember try the connector one way if it doesnt work than flip it 180 degrees, the board should also give you the side of positive [+] side, you put the color wire to the [+] side most of the time. the photo shows you the placement of connector and the connector are printed on the cable match the colors of the board to the connectors
The Front Heat / Ac Work's ! ! ! ...When It Wants TOO
there is a blower relay circuit board located right by the blower motor which sounds like your problem to me i've worked on several that had the same type problem and thats what it was. the two blower motor wires will plug into it and there are two screws that hold it on
1984 honda500 v twin not runningon all cylnders what will fix this
check spark plugs are clean ! swap plugs over and see if the cylinder that wasnt working now works , are both plugs sparking , compressions ok , put finger over each holes and see if both feel the same ? any more info you have mite help me find the problem !!
Fridgitaire affinity speed control board fix
Are you looking for the easiest way to do the job, if so, you need to get behind the machine, unplug unit, and get the rear access panel off the unit. Pull the belt off, then using a 5/16", drop the 3-4 screws that hold the motor on, then slide it a little out of the way. Speed control board sits in that white box right next to motor. There is one screw that holds it to the side of unit, and two screws that hold a "L" brace to the board and the floor. Watch where the wiring goes to the different points, then slide the box towards the front and lift to remove. Get board in better position, remove wiring, then put new board in. WARNING the insides and sides of the access hole area's are RAZOR sharp. Use good gloves or severe caution while working inside and near the edges. You can very easily loose a finger or cut yourself very badly. Good Luck!!!
All the buttons on my tv remote work but the volume, What do I do ?
Sounds like they are not touching the board inside the remote. for that take the remote apart reposition the board inside of it (careful not put fingers on board, sides only) make sure they are working and then put the remote back together.
My sony ericsson w610i shows only white screen n not working
the problem is with the display...the board inside mite have a small bent or disconnection. its better to show it to a mobile expert in such cases.Just because its SONY it is very delicate.. things might get worst if we keep our hands on it..
thanks for rating Good luck
My galaxy dx99 my frecuency counter is not workin adn the chanel nomber too.please help my.need to see the diagram for frecuency counter that help me toooooo than [email protected]
Hi and welcome to FixYa,
Your post "...need to see the diagram for frecuency counter...", please see below schematics.
Good luck and thank you for asking FixYa.
Panasonic copier 8016p error code 05-11
Communication problem between main circuit boards inside machine, mite also be a loose connection between boards. Copier on good surge protector? Not some cheap strip type? One that also protects fax line and network connections?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jl audio 500/1 problem
Usually all amps spark a little when hooked up again after a while of no use. this happen cause there are many little capacitors inside to keep the amp running when hitting long bass notes. I think the reason you have been having problem after replacing the transistors is because there not the rite model number or maybe the polarity. You mite have to call jl and ask them if they have any in stock or google the model number of the transistor and buy them and replace them and see if it work. if it doesnt work then it mite be something else inside.
1helpful
Bettery replacement for Navman 510
Easy if you're comfortable opening up the receiver and working on electronics. To obtain a 'new' battery you can use Ebay, search for "navman 510 battery" and you should find some for sale. They seem to sell for about $20 including shipping. First find a good environment to work on the receiver, someplace where you can have good lighting and a good place to put parts. You may want to lay down a towel or something so you don't scratch up the receiver and also so if you drop the screws they don't bounce away from you.
First remove the SD card, then the screws from the back. After you have the screws out, slide your finger nail (NOT screwdriver) along the seam pressing inwards, the cases should separate and you should then be looking at the inside of the receiver. First, you'll have to disconnect the antenna connector. Then you'll have to remove some screws holding down the main circuit boards inside. Be careful when removing components that you don't crack the boards, they're very thin! After you have the boards out you'll be able to unplug the battery from the main board (they ran the cables under the boards so you have to remove them to get the battery out). Put the new battery in and reassemble.
Make sure to fully charge the battery before you first use it.
Top Galaxy Radios Radio Communications Experts
Marvin
Marvin
Johnny 1000
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
