Question about Canon PIXMA MP530 All-In-One InkJet Printer
MP530 Color Calibration Terrible
I have tried everything I can find, short of installing separate calibration software (because I don't know which one to use) on a PC (*groan*, I know), and with any image, the brightest red will print a strange dark oxblood color. I have used Photoshop, Quark, and just printed from a Word doc, and I get the same results. I have used brand-new cartridges, and I have refilled cartridges. Nothing seems to keep the printer from wanting to add mud to my red. I have looked at my CMYK plates, and they do not indicate any Cyan in the red, so I think it is an internal calibration in the printer. ??? Can anything be done?
Posted by dorkshorts on
5 Related Answers
Anonymous
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
Anonymous
SOURCE: Canon MP 210 gives E5 error and will not print.
Open Cover and see if the cartridge come over on there own, if not you have a paper jam. Look at the roller and see if there's any paper jammed. Good luck
Posted on Jun 06, 2009
killer10
SOURCE: MP830 Cyan Ink won't print
To Fix the stupid Cyan, just unplug the printer, it may take more that one time unplug, its stupid problem, printer needs to reset, I have a full ink of Cyan but it says this "There is more than one Cyan" on the dispaly on the printer, and windows that its missing. I don't know what idiots programmed the printer. but screw them.
for cool stuff check out my site http://www.gagla.com
Posted on May 03, 2008
Anonymous
  • 81 Answers
SOURCE: Installed all new ink cartridges and now poor printing results
hi,
hope this tip can help your problem your printer ink,
try to put your ink cartridges the printing head on top of a cotton with an alcohol in it. 40% it can. for about 5 minutes or less.
after that whip it with dry cotton. and install it again. and do again the cleaning procedure of the printer head.
and also check your printing preferences about print quality.
Posted on Nov 28, 2008
William Charnigo
  • 615 Answers
SOURCE: Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Posted on Mar 28, 2010
Load valid paper for color calibration
When you perform a color calibration on an HP designjet you must use a certain paper. HP bond plotter paper should be one of them. If you are not concerned about perfect color calibration you can lie to the printer and tell it you installed the paper it wants. If it cannot detect that this paper is not exactly what it is looking for it will perform the color calibration. Just keep in mind that it might not be exact or may fail.
Oct 16, 2013 | HP DesignJet Z2100 InkJet Photo Printer
What is color calibrator?
Wikipedia says:
The aim of color calibration is to measure and/or adjust the color response of a device (input or output) to a known state. In International Color Consortium (ICC) terms, this is the basis for an additional color characterization of the device and later profiling.[1] In non-ICC workflows, calibration refers sometimes to establishing a known relationship to a standard color space[2] in one go. The device that is to be calibrated is sometimes known as a calibration source; the color space that serves as a standard is sometimes known as a calibration target.[citation needed] Color calibration is a requirement for all devices taking an active part of a color-managed workflow.
Jan 20, 2013 | Computers & Internet
Only black white
Thanks for questioning, pl don't post shot cut questions,your inputs are more valuable for us to give straight away trouble shooting..>Check all cartridges are fully loaded?>Before any body attempted for trouble shoot?>Are you checked for supply status?> Are you performed color calibration?**** Do color calibration (go to menu,system set up,quality,color calibration,calibrate now)Take supply status print out(go to menu,scroll to reports,scroll to supply status, enter in to for print)check all colors are printed are not? If printer take print out from system or print demo page from printer menu.. check print quality...and color calibration..****Remove supplies.. observe while closing the door right side in the supply bank supply contacts engaging or not.(while closing the front door the 'bios voltage contact leavers' engages with the cartridge contacts for passing the voltage in to the cartridge for charging,see the attached snap shot)if these are broken,no contacts or not properly driving by the mechanism, results no print.. check for these contacts...*** alignment disturbed, its major issue users cannot perform this activity..submit in service center for this major issue.
Jan 08, 2012 | HP Color LaserJet 2600n Printer
Hp design jet 5500ps prints dark. whenever we have a dark color printing, it darkens everything around it, even when it is set to high quality. our posters are coming out extremely dark. could it be a...
It could be a paper issue. Make sure the paper you are printing on is the type paper you told the printer you installed in the paper type setting (Plain Paper, Bright White Injket Paper, etc.)
Aug 02, 2011 | HP DesignJet 5500PS InkJet Printer
I changed a toner cartridge and now it is not alligned and I don't know how to allign it. I have an HP CP2025 and I have tried doing the cleaning and printing the test pages. I don't know what to...
Calibrate the product
Calibration is a product function that optimizes print quality. If you experience any print-quality problems, calibrate the product.
1. Open HP ToolboxFX.(in your PC)
2. Click the Device Settings folder, and then click the Print Quality page.
3. In the area for Color Calibration, select the Calibrate Now check box.
4. Click Apply to calibrate the product immediately.
Jul 10, 2011 | Office Equipment & Supplies
I have a docucolor 12 and x12 fiery. I am trying to calibrate from the fiery. It will printer calibration page, but it can't measure scanner. It comes up with check scanner cable connection. I have tried...
You should have a color separation guide with small gray scale from Kodak. You put the gray scale and the calibration sheet on the glass and follow the instructions from the fiery display.
Jan 02, 2011 | Xerox DocuColor 12 Color Copier
At a startup performing calibration initialization long HP Color Laserjet 4600dn
Calibration bypass
During certain diagnostic procedures, you will need to bypass the automatic calibration that is
performed whenever the printer is turned on.
To bypass calibration
1 Turn the printer on and watch the control panel display.
2 When the display begins showing the memory count, press and hold until all three lights on
the control panel are lit.
3 Press .
4 Press PAUSE/RESUME. The display should show SKIP DISK LOAD.
5 Press until SKIP CALIBRATION is highlighted.
6 Press . The printer will skip calibration and then continue its power-on sequence.
Please refer here for further details if required
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Nov 26, 2010 | HP LaserJet 4600dn Color Printer
When printng the color is terrible i have used the align and clean print heas utilites but still prints terrible almost negative like pictures
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Sep 13, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can't calibrate new Stratford Labs GFP-001
Can't calibrate the new Stratford "Digital Image Copier" GFP-001.
Followed all instalation instructions till I got to the part where it said that the unit had to be calibrated for the first time used. It said to "Click" on the "calibrate" button to perform the calibration,
but there was no calibration button shown, or no on screen desplay pop-up. Would like to know what I can do to rectify this problem. I am using an Acer Laptop with "Vista Home Premium";
which has 2.0 USB Ports which is called for. Does this device need to be calibrated, or can it be used without the required calibration?
Thank you,
Gerry Hall
Jun 07, 2009 | Logistixs Campus Media Publisher 2003...
Canon color laser printer 5000
I cannot calibrate the Canon LBP 5000 color printer. The option is grayed out. I have the same problem. Please send me an e-mail to [email protected] when you get the solution.
Thanks in advance.
Apr 02, 2008 | Canon Wordtank G55
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
326 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
