ITA A LATE MODEL TOSHIBA NOTEBOOK
SOURCE: DVD Disc in my Toshiba Laptop Corrupted
make uninstall driver for CDW/DVD then re-boot.
Install the driver for CDW/DVD and use. It will fix your problem.
Thanks
Iqbal
SOURCE: Toshiba Satellite wireless switch doesn't turn on
Ok, if your using Vista, what i want you to do is right click "computer" select "manage"
and then "device manager", then click on the + sign next to "network
adapters" and right click on the wireless network and "un-install" the
device, reboot the PC and wait for windows to detect the wireless
card and install the drivers for it, this will appear in the system
tray (bottom right hand side) when its done try to connect again
keep me informed please and thanks for using Fixya
SOURCE: Toshiba Satellite A105 PC Notebook, DVD/CD Drive.
You can't just change it from pio to udma. Go to Control Panel, System,Hardware,Device Manager, then expand IDE ATA/ATAPI, then right click on Primary IDE and select uninstall. Do the same for secondary IDE. Then just reboot your system, and it will autodetect all IDE devices. After that when you check, you should not have any devices in PIO, and your burner should work correctly. If not, stick it in a hyperbaric chamber for 2 days and see if that helps. __________________
SOURCE: Toshiba M35X-S161 motherboard replacement issues
How to remove back cove rof my Toshiba M35X-S161 to get the charging input jack to repair it?
SOURCE: need sound for toshiba satellite m35x s161 model
Download this driver from Toshiba support:
http://cdgenp01.csd.toshiba.com/content/support/downloads/sm35xsndx.exe
