Question about HEWLETT-PACKARD T790 InkJet Plotter Printer
My plotter will just click and wont return
When I try to boot up my plotter it stops at about 94% and the return just sits at one end and clicks and clicks and clicks. Just locks down and wont proceed
Vinaya Kumar Kuchipudi
  • HEWLETT-PACKARD Master
  • 1,121 Answers
If carriage sits at right side., might be service station jammed, its not releasing the carriage assm..its critical issue., dont force to pull out the carriage, it may damage print heads.. pl contact professionals..
Posted on Sep 23, 2014
How do I remove the c-map card from the unit?
Hi Bernie
From your owners manual, (Page 94) push in on the C-card lightly and UP until you hear a click. The card will then eject.
I've included a link to your owners manual should you require it.
Hope this helps
-Steve
http://si-tex.com/pdf/1401916229Chart-Plotters-3-08.pdf
Mar 05, 2015 | SITEX ColorMax 6 LCD Chartplotter (
Printing sitting in queue wont print
The print spooler may not be working.
Start and stop the print spooler Windows XP
To start and stop the print spooler open Computer Management, click Start, click Control Panel, double-click Administrative Tools, and then double-click Computer Management. In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler. Do one of the following depending on the task you want to do:
Click Stop to stop the service.
Click Start to start the service. When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
Aug 28, 2012 | Brother MFC-290C Printer
Why wont my HP COMPAQ nx6110 boot up!!
1) Download (0x00000007b) repair utility.
2) Install program and click Scan button.
3) Click the Fix Errors button when scan is completed.
4) Restart your computer.
Jul 03, 2012 | Computers & Internet
I need the drivers to install a plotter ENCAD CADJET 2 in a Windows 7 ultimate
Cadjet2 - All the drivers, utilities and more are available from the following site:
http://www.wideformat.kodak.com/support/Printer%20Reference/CJ2.asp
Aug 12, 2010 | Encad Kodak Premium Backlit Film 36" X...
Print jobs stuck in cue
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone.
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jun 25, 2010 | HP LaserJet 8500 Color Printer
HP 750C Moved across country, bought a new iMac. Forgot how to set up plotter settings so the mac can find it. on the network. I remember having to make changes on the plotter, but can't remember what...
Hello, the plotter should be seen in your print and fax preferences (apple menu, system preferences, print and fax): In the print and fax preferences panel, you can click on "+" at the bottom left of the window, you should see your plotter appear in the window, and click on the "add" button Best regards
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
94 cutlass supreme wont start
It sounds a Lot like you have some Trash inside the Fuel Tank .Also, Check the Fuel Filter and Starter.
Jan 15, 2009 | 1994 Oldsmobile Cutlass Supreme
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
I have an hp1055cm plotter that is leaving streaks on the page i.e. it makes a clean first pass and on the second pass (as the print progresses)it is like the head does not reach the paper and leaves the...
Configuring the HP1055CM Driver Right click on the icon for the plotter (for WinXP, go to Start -> Printers and Faxes) and select Properties. Make the following changes:
On the tab marked General, click on the Printing Preferences button.
In the window that pops up, select the Paper/Quality tab choose Roll Feed for the Paper Source. Next, click on the Advanced button:
• Under the section called Graphic, click the down arrow next to ICM Method and choose "ICM handled by Host System".
•Under the section on Document Options, there is a section called Postscript Options. Click on the "+", then change "Optimize for Speed" to "Optimize for Portability". Also make sure the "PostScript Language Level" is set to 3.
• In the section Printer Features, set "Scale to:" to "No Change".
• If you wish, under Paper/Output, you can select a default paper size appropriate for the plotter: ARCH E (36in x 48in) seems reasonable. (Note that when you print from an application, you may want to adjust the paper size for your specific plot, and you should also set your document to an appropriate smaller size in the application.)
• Click on OK buttons until you get back to the main window for Properties.
On the properties tab marked Advanced, click on the radio button for Print Directly to Printer.
Also click on the Printing Defaults button, then the Advanced button. If you see a similar set of postscript options like you just went through above, repeat the process to set the ICM method, set postscript options to "Optimize for Portability" and Language Level to 3, change the paper size, and set "Scale to" to no change.
Click on OK buttons until you get back once more to the main window for Properties.
Under the property tab for Device settings, you should change the Output Protocol from ASCII to JPEG. (If there is no JPEG option, select Binary.) It is also helpful to change "Send CTRL-D at end of job" from YES to NO, but that isn't crucial. Under the section marked Installable Options, change the amount of installed memory from "Default" to the closest value below 96 MB, probably 80 MB. (The plotters actually have 96 MB, but since not all of that is available for user jobs, it's better to claim the smaller value. This is still larger than the "default" size, which is about 48 MB.)
Click OK.
Nov 06, 2008 | Office Equipment & Supplies
HEWLETT-PACKARD T790 InkJet Plotter Printer Logo
80 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Harrie
Duke Bells
George Mclaughlin
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
