Question about Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius wt540 where is the pressure switch
Posted by George Rycroft on
5 Related Answers
Wayne Rees
  • 3 Answers
SOURCE: hotpoint aquarius wt540 wont pump out water
Hiya Barry, I have the same machine and for the last 3 days have had the exact same problem...mini load and reduced crease as well as power light flash right when it comes to drain...?
I have scratched my head and done lots and lots of research, reckon I could design and build my own washer now lol, anyway, I fitted a new pump and ran it, thinking this is it sorted, went out and got a call from our lass...doing it again.
Right, gonna have to get me hands dirty...I removed the drain hose (Ignore the pump for a second, I'm talking about the grey hose that goes from the pump to the sink) from the sink and poked my fingers as far as they would go...debris, I then removed it from the other end (Pump) so I had a long hose in my hands, not attached to anything at either end....cleared it and again, loads of debris (Fluff, plastic etc) and put it all back together...turned the old fella back on and running a wash right now as we speak...happily spinning round at 1400rpm and throwing gallons of water down the sink...I would consider it fixed.
So I can most definately tell you that you have a blockage somewhere mate, I'd get your hands in the toolbox and pull that pipe off, doesn't require any level of experience, just the ability to put things back as you found them...
Hope that helps
Posted on Dec 01, 2008
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: hotpoint wt540 can't get filter out
It is possible you have got something stuck in filter, and this is what is stopping it coming out, you are turning it the right way, you will just have to stick with it, and keep trying to ease it out.
Keep trying to eaes it in and out, and you should be able to remove it eventually.
Plz rate this solution.
Thanks.
Posted on Dec 14, 2008
Anonymous
  • 679 Answers
SOURCE: Hotpoint aquarius WF541 will not switch on
If the washer doesn’t operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power, or, if the motor stopped mid-cycle, the machine’s overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself. Then restart the machine. Otherwise:
1) Be sure the machine is plugged in and turned on. If necessary, check the receptacle it’s plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer, and check the power cord. If necessary, replace the cord.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch. If it doesn’t click when you do this, it’s probably broken. If you’re experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call a repairperson.
5) If the washer still doesn’t work, the controls may be faulty. Call a service person.
Thanks for your question
Posted on Jan 03, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
reddyanantha
anantha reddy
  • 205 Answers
SOURCE: hotpoint aquarius wd440. Flashing lights
hello mam please check the timer switch.
Posted on Oct 04, 2009
Does the outer drum on a hotpoint WT540
All outer tubs on most Washing Machines these days are sealed.
Therefore you cannot split the tub to get inside and change the bearings. instead you have to change the whole tub assembly as a complete unit. Not an easy job.
Oct 27, 2014 | Hotpoint Washing Machines
Wt540
how-2-repair.com i found this web site for you
Mar 31, 2014 | Hotpoint Aquarius WD63 Front Load...
Machine wont spin
check motor brushes or blocked pressure chamber.
Feb 09, 2014 | Hotpoint Aquarius WT540 Front
Hotpoint wt540, reduced creases and extra rinse lights are staying on all the time
1) clean the contacts ribbon with erase pencil and put a little ethylic alcohol.
2) try it 3) if the problem persist the control board is faulty.
God bless you
Oct 11, 2012 | Hotpoint Aquarius WT540 Front
My hotpoint aquarius TCL770 isn't drying clothes
Good evening
There is most likely something wrong with the electricity in the machine.
Kolbrun
Feb 26, 2012 | Hotpoint Aquarius WT540 Front
Hotpoint aquarius wt540 - it has started to malfunction
Most likely a control board failure, you need a service tech to come out.
Oct 27, 2017 | Hotpoint Aquarius WT540 Front
Hotpoint aquarius wt540 no power in machine no light at switch
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch/door switch
The washing machine may not function if the lid switch or door switch is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control and start switch as well.(You can test the continuity or, resistance level of the Lid switch with a multimeter(ohm).
Jul 16, 2009 | Washing Machines
Drive belt came off Hotpoint Aquarius WT540
At each side of the lid there is a small plastic cover. Remove these then take out the screws. Lift the lid at the front and push it back then lift off.
Thankyou for using Fixya.
Jan 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wt540 can't get filter out
Thanks.
Dec 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF220 Front Load Washer Logo
21 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
