RCA LED22B45RQD 22" 1080P LED TV/DVD Player Refurbished LED22B45RQD Logo
Kaylee Lamb Posted on Mar 07, 2014
Rca tv/dvd wont turn on
Red power light is on but when you hit power on the remote, the red light goes off but the tv wont come on
5 Related Answers
Anonymous
  • 556 Answers
  • Posted on Oct 06, 2007
SOURCE: RCA 27V412T FPA LOCK ON & REMOTE LOCK
If the front panel lock is on, you will need a working original remote (or a universal remote properly programmed for RCA) to turn the set on. The IR receiver is next to the buttons on the fromt but the RCA IR receivers are very reliable, and I have yet to see a bad one in a modern RCA TV. Once you turn the set on by remote, you can enter the menu and turn the FPA off.
Bill England
  • 18 Answers
  • Posted on Feb 25, 2009
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 17, 2009
SOURCE: tv wont turn on, RCA D56w20, 56" rear prjection
replace the flyback 259296 and the CP150 capacitor. You can get the replacement parts with free instructions at the following link.
http://servicemanuals.vstore.ca/
jtrag
James Trageser
  • 112 Answers
  • Posted on Jul 21, 2009
SOURCE: RCA BIG SCREEN TV WONT TURN ON HELP !!!!!!!!!!!!
Try unplugging it for about 30-60 seconds, then plug it back in and before you turn it on, make sure there is a good video source going to the TV either from Satellite/Cable or a DVD player or something.
If this doesn't work, try unplugging it a bit longer and then plug it back in and try again. If it still does not work, you may have to take it in and get it serviced.
Usually when devices power themselves off like that, there's something wrong...
I hope this helps :) Good luck!
Best Regards,
James
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Nov 14, 2009
SOURCE: I have a RCA L32WD12 that suddenly turned off and
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Can my remote control RC00136P pair with my Vizio dvd player?
  1. Turn on the TV or device you want to use with the universal remote.
  2. Press and release the TV button on the RCA Universal Remote. (The red light on the remote will begin to flash)
  3. Now simultaneously press and hold the Power and TV buttons on the RCA Universal Remote. The on/off button will be illuminated and then turn off. After a moment, the button will relight, it should remain on.
  4. Aim the RCA Universal Remote at the TV. Release both the on/off button and the TV button on the RCA Universal Remote simultaneously.
  5. Next, press and release the Play button on the RCA remote. The TV or component should turn off after about five seconds. If there is no response, continue to press the Play button until the TV or other device you are programming turns off.
  6. Now press the reverse button. If the TV or device does not turn back on, continue to hit the reverse button until it does.
  7. Press the stop button once the TV has turned back on, this will save the programming settings.
  8. Your RCA universal remote is now ready to use
I need help I just won a tv but it didnt come with a remote but I have a RCA remote transmitter. Im trying to program it for the tv but I dont have the book anymore can you please help me The tv is on but...
This Web page should allow you to find the codes for any devices you want to add for this remote.http://remotefinder.rca.com/default.aspx?site=rca
Other than that there is an easy way to program this remote.
1. Turn on the device by hand. 2. Hold down the device name key.(hold the TV button to program a TV) 3. While holding down this key also hold down the power key until the red light turns off and comes back on. Then release both buttons. 4. From here hit the power button repeatedly until the device turns off. 5. Hit the stop key at the bottom. Now the remote is programmed for that device.
Can not control the volume on an rca
Ok to reprogram the remote and this only works if you just use the remote for the tv and the receiver. Like i was saying to reprogram the remote hold the tv button till all the top lights flash, then push the red power button, then hit the up arrow button slowly til the tv cuts off, once it cuts off hit the pound (#) button. The top lights should blink three times, that should reprogram the remote, If it is a tv/vcr combo or a tv/dvd combo then there isnt a code for it. Also there is a series of years that the rca tv's wont take a full code and u can just control the power and the tv channel
1helpful
Missing code for comcast remote to work new rca tv
Hit tv then hold the setup button untill in flashes....then you type in 991 and then hit tv power tv power.... untill your tv turns off when it dose hit setup to lock the code
My RCA model D52W20 will not fully power on when we try to turn it on by using the power button on the tv or by using a remote. There is a click and the green light that shows power lights but the tv does...
unfortunatly the rca d52w20 is a flawed tv, they a high rate of problems with the power supply and convergence amps, both parts are no longer available, i have scrapped those sets that were barley a year and a half old. sorry and good luck
78helpful
6answers
I have lost the instructions for my jumbo touch screen remote
I was here originally with a problem identical to one posted and found that the best solution posted was only partially working. My husband and I were able to get the tv on but that was the extent of it. Once on the remote was not working. Out of frustration we figured out the that if you practice the exact steps after the tv is turned on,
1 hold the set button untill the red light comes on
2 press what you want to set (tv,vcr,dvd,ect.)
3 press power botton aim at unit and wait until it turns OFF then quickly press ent.
This did it for us and we are now happily watching tv again without having to toss our beloved giant remote into the garbage. Hope this helps!!!!
25helpful
2answers
Need instruction to program the remote RCA 450
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
1helpful
2answers
Need codes for the RC450 remote
ok
37helpful
7answers
RCA RCR311W remote
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
42helpful
5answers
Trisonic ts-rc488
OK EVERYONE I FOUND ALL YOUR ANSWERS , IM JOHN FROM NEW JERSEY [email protected] , FOR THE TRISONIC UNIVERSAL REMOTE CONTROL , TC-RC488 AND MAYBE OTHERS , INSTEAD OF THE CODES THIS IS EASIER,TURN ON THE TV OR VCR ETC. FOR THE POWER MUST BE ON WHILE DOING THIS PROCEDURE , PRESS THE YELLOW SET UP BUTTON AND THE DEVICE KEY U WANT SUCH AS TV1 OR VCR1 AND HOLD THEM BOTH DOWN UNTIL THE RED LIGHT ON UR REMOTE STAYS ON THEN IMMEDIATELY AFTER HIT THE YELLOW SETUP BUTTON AGAIN UNTIL UR RED LIGHT STARTS BLINKING THEN POINT THE REMOTE AT YOUR TV OR VCR AND KEEP HITTING THE RED POWER BUTTON AS THEN YOUR REMOTE IS TRYING TO FIND A CODE AND WILL EVENTUALLY FIND A CODE , AND YOUR TV OR VCR WILL SHUT OFF , THEN THE RED LIGHT WILL BLINK LET IT BLINK UNTIL IT GOES TOTALLY OFF, THEN HIT THE POWER BUTTON AND YOUR REMOTE SHOULD WORK , SOMETIMES YOU HAVE TO HIT THE DEVICE KEY AND YELLOW SETUP KEY SEPARTELY AND THEN THE RED POWER BUTTON, I CALLED TRISONIC AND ACTUALLY HE HELPED ME AND I HELPED HIM , HE SAID I SHOULD WORK FOR TRISONIC , THIS IS A QUICK SEARCH , NOT REQUIRING ANY CODE NUMBERS, HOPE I HELPED YOU ALL SINCERELY , JOHN A.CLINE , CHECK OUT MY LIST OF LYRIC BOOKS AND MUSIC AT WORDCLAY.COM BYE!!!!!!!!!!!!!!!!
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
