Computers & Internet Logo
R
RachelReaper Posted on Mar 06, 2014
Dell inspiron n5040
N5040 on win 7 64-bit home premium. Got broken or black screen, can hear fans on startup but then starts to beep 4 times,. Ive tried cleaning ram but still same problem. Before this happened i downloaded and updated drivers, was using 2 displays and had 2 versions of windows
Richard flores
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Mar 07, 2014
Richard flores
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
1506
Points
31
Hello Rachel,
The memory of your laptop was dump. Open the back panel of your laptop using the screw driver open it.. then you will see the your memory card remove it and clean it with the eraser .. or if you have two memory card just take off the other one. and try to on. If the problem occur swap the other one. I'm sure it will work fine now..
3 Related Answers
Anonymous
  • 52 Answers
  • Posted on Jun 10, 2009
SOURCE: dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Alun Cox
  • 2679 Answers
  • Posted on Mar 22, 2010
SOURCE: acer aspire 5315 beeps on startup
See here
http://www.computerhope.com/beep.htm
Anonymous
  • Posted on May 02, 2010
SOURCE: Accesing the fan on a Dell Inspiron 1501
Here is Dell's support page on getting to the fan:
http://support.dell.com/support/edocs/systems/ins1501/en/sm_en/fans.htm#wp1000550
M5030 won't start,just beeps 7 times.
This is a motherboard and power supply issue - you most likely cannot fix it yourself. I have attached a link where someone got their system back up temporarily, but it won't last. You need to replace the motherboard ASAP.
http://randythetechprofessor.com/how-i-fixed-the-dell-inspiron-m5030-seven-beeps-at-startup
1helpful
Hello i have my laptop dell n5040 xp win installed also dowload idt high defenition audio but still audio sound not working what did to install i dont understand. please help
Completely remove whatever sound drivers you do have installed, restart, download this: http://ftp.dell.com/audio/R302718.exe
Once downloaded install the sound driver I have provided the link for. If it still doesn't work, please post back here with your DELL service tag. This can usually be found on one of the labels on the underside of the laptop. I may be able to help further if you can provide that information.
Dell inspiron laptop N5040 3 beeps interval 3 beeps black screen
Explain the intervals at which it beeps, either 2 short beeps and a prolonged beep. does the hard disk LED blink? if it does its display inverter problem. if no blink on hdd LED its either RAM or cpu failure.
Will not power up
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
I need a driver for a Hard Disk Drive for startup repair.
You will have to download ISO image of Windows 7 Home Premium, 64bits, burn it to a cd, then boot from cd to get to the repair mode.
Link below for download
http://getintopc.com/softwares/operating-systems/windows-7-home-premium-free-download-iso-32-bit-64-bit/
2answers
I use dell inspiron 1440. today onwards the bt travel mouse does not connect to my laptop. how i rectify this problem
reinstal the driver for it and should work or check in start-my computer-right click manage-device manager -action -scan for hardware changes.
2answers
Dell Inspirion 1521 Laptop Microphone Wont Work
checklist:
1. sound driver 2. microphone settings in volume control applet 3. tap test (tap the area around the microphone and see if eg Sound Recorder picks it up) 4. external microphone
If you get to step 4 before you get anything then your problem is one of missing or damaged microphone.
Grand Canyon Tech
Grand Canyon Tech
