When I go to turn our savoy ceiling fan on with the remote the red led in the remote stays on and nothing happens. I tried putting a fresh battery in with the same result. Time for a new remote?
Sounds like you need a new transmitter. The light is a battery indicator light.
Posted on Mar 08, 2014
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
SOURCE: Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Posted on Jan 24, 2009
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
SOURCE: Hampton Bay 60" Brookedale fan remote not working
The Remote (TRANSMITTER) control AND the RECEIVER must both be set to the same CODE in order for the REMOTE to operate the fan.
!!WARNING!! YOU ARE ABOUT TO ENTER HIGH VOLTAGE ELECTRICITY ZONE!!
The RECEIVER is located in the CANOPY, the part of the fan assembly next to the ceiling which is also called the Hanger Bracket.
At the bottom of the Canopy you will see what looks like a large flat washer. Rotate the washer counter-clock wise to release it.
Then rotate the Canopy counter-clock wise to release and lower it. You will see the RECEIVER, which will have a short antenna at one end, tucked in among the electrical wire and bracket. Simply pull the RECEIVER out and you will see the CODE switches. Remember to set both devices to the same CODE.
Good luck. :)
Posted on Apr 26, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Jun 29, 2018 | Dryers
Jun 30, 2017 | Building Materials
Nov 21, 2015 | Savoy House Televison & Video
Oct 22, 2015 | Dryers
Aug 08, 2014 | Savoy House Televison & Video
Apr 09, 2014 | Hunter Ceiling Fan Light Remote Control
Nov 05, 2012 | Emerson 44 Curva Sky Ceiling Fan In...
Sep 01, 2011 | Hunter Ceiling Fan Light Remote Control
668 people viewed this question
