The error code is letting you know that there is a problem in the upper heater unit in the copier. It could be a bad thermistor, a bad heater, a bad thermal switch, or a combination of any of them.
I would recommend calling it in for service as all of these parts are not user servicable.
The error E007 is the fuser film that's faulty!Its got a white patch on the side and the machine is not reading the patch!If there is a canon dealer close by they can replace it as u need to strip down the machine to get the fuser out!Its a separate spare and wont be expensive!!
Hi, are you sure that you have clc 1140 Copier? Because E007 isnt clc 1140 error code. These error code is related to machines with teflon folie, in newer date b&w copiers.
These error means that copier cant see fixing folies mark, and only that you can do is to replace fixing film ( folie ).
Not enough info.
depends on where on the right it stops, if coming out of tray check tires to see if they are smooth.
If stopping on path could be a sensor
