Works fine except RPM of RH desk is a bit slow.
SOURCE: TEAC X1000R Stereo Tape Desk (reel to reel)
usually its a capstan drive belt. $10-18 for the belt & 30mins repair time - you'll be up &brunnin b4 you know it [email protected]
SOURCE: Teac A1200U R/R runs slow
This could be anything from a defect in the power supply to a defecive motor to a slipping belt. Without seeing the actual unit, it will be near impossible to determine which is the root cause of the problem. Given the unit's age, it should get a complete overhaul including the replacement of all rubber parts. Parts are still available for these. Expect a parts cost in the $50 range. Take it to an audio repair shop that has been around for a while. They will be gald to get to work on such a unit.
Dan
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
