Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Spin cycle won't run. I removed the motor to see if I could changes the brushes- but this model does not have removal brushes. I re-installed the motor and tried the spin cycle and it worked like a charm! so I attached the back cover, slid the washer back into place and tried a "quick wash cycle" with 2 towels and the next thing I know water is all over the floor! I had orginally checked the drain for cloggs and must have not closed the cap tight enough. Either way, the spin cycle still would not run. Any suggestions? I am going to revisit the drainage to see if something is potentially blocking the drain ( I cleared out 2 hairpins with my initial examination)
SOURCE: my bosch nexxt 500 series washer won't spin
possibly the motor brushes.
take back panel off. disconnect motor. remove bolts holding motor in and take out motor. check condition of brushes
Posted on Oct 18, 2008
SOURCE: Bosch Nexxt Premium Washing Machine Drainage Blocked. Cleaned out impeller still not working.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect. Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining. Replacing the pump on a Bosch machine, please check this link for tips:
Posted on Jul 03, 2012
