Question about Health & Beauty
I have mayfair freerider and every now & then it stops then goes again there are no green light flashes.
Posted by norman saunders on
Rob Hill
  • Health & Beauty Master
  • 1,414 Answers
Hi, does it just cut out ?, if so there is one fault that can cause that, worth checking, try pressing the lever in the upwards or downwards direction while going along, if it doesn't cut out , the throttle pot needs replacing ... it's worth also checking the battery and controller connections making sure they are a good fit and tight...
Other causes:
Battery voltage dropping too low...
Brake breaking down..
Regards
Rob
www.gewizrepairs.co.uk
Posted on Mar 06, 2014
4 Related Answers
lennieg2000
  • 692 Answers
SOURCE: I have a mayfair freerider scooter and all of a
try borrowing a charger from a friend or neighbor to charge your scooter If it charges the batteries then your charger is bad if it doesn't charge your batteries then the batteries are bad Hope this helps
Posted on Apr 18, 2011
gewiz
Rob Hill
  • 1414 Answers
SOURCE: Mayfair freerider mobility scooter - keeps losing
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Posted on Oct 18, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: freerider mayfair, no life at all in scooter
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Posted on Oct 01, 2009
MarK
  • 33 Answers
SOURCE: Mayfair freerider scooter shows reverse polarity on battery meter but wires good
Check to make sure you have a good ground.
Posted on Nov 17, 2012
Hi, my wife's freerider Mayfair mobility scooter keeps going slow, have turned speed control down but still seems to loose power, doesn't stop just slows then reverts back to the speed set.
there are four possible reasons why a mobility scooter loose power including the user weight (vs. max weight of a mobility scooter), the weather condition, the riding routine and the battery age. You can check those factors to figure out the root cause. http://trustedmobilityscooters.com/reasons-mobility-scooters-loose-power
May 06, 2017 | Cars & Trucks
How to change the batteries on a freerider mayfair?
The batteries are located under the seat. you will need to remove seat and then the plastic cowl that covers the batteries and drive compartment.
Mar 28, 2015 | Health & Beauty
How do I get to the batteries on my mayfair freerider
Lift the seat off. remove seat mount by removing pin or screws. Lift plastic cover off carefully but mind cables going to lights. These can be unplugged. And there should be your batteries.
Oct 19, 2014 | Health & Beauty
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
Feb 26, 2013 | Free Rider 2 Freerider Luggie Compact...
I have a mayfair freerider scooter and all of a sudden it wont charge up. charger says abnormal charge. Is there something wrong wiyh the batteries or charger?
Apr 17, 2011 | Universal Health & Beauty
Mayfair freerider mobility scooter - keeps losing power, especially on slow speed
Regards
GeWiz.
Oct 18, 2009 | Health & Beauty
Freerider mayfair, no life at all in scooter
Regards
GeWiz
Sep 30, 2009 | Health & Beauty
Wash light flashes
Hi LIANNEshaun,
I'm Harvey the Master Plumber.
Your problem is: you switch on dishwasher and it seems to start then light goes onto wash and the machine stops and green light flashes
Could we have the make, model and year please?
Feel free contact me again!
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Health & Beauty Logo
186 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
