Question about Sharp AR-M355N Copier
Code F2-02 Toner already changed this morning on copier and now the printer displays check toner cartridge CODE: F2-02
Posted by Stacey on
Printer Help & Support
  • Sharp Master
  • 783 Answers
Have you tried the sim 25-1 to see what the toner value is? Sharp pretty much just says check the connectors and the toner sensor then replace the toner. If you are using refilled toners that could be the issue. These are the troubleshootings steps for F2-02 in SM. Techsupport Printer
Posted on Mar 06, 2014
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
Inno Laur
  • 93 Answers
SOURCE: crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Posted on Oct 16, 2008
Anonymous
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
Anonymous
  • 118 Answers
SOURCE: Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Posted on Aug 31, 2009
Anonymous
  • 63 Answers
SOURCE: Error code f2-04 after changing to new toner
F2 04
  • Identification error
  • Model error
  • Type error
  • Destination error
  • Data abnormality
  • Misc error
It is always recommended to use OEM toner. The toner you need if AR-310NT
Posted on Oct 12, 2009
My Toshiba toner near empty, but i replace already.Now it is display toner near empty k
Go to job status, press the TONER tab, press REPLACE TONER CARTRIDGE. answer yes. Then replace the TONER cartridge. Press FINISH.
Jul 21, 2016 | Toshiba E-Studio 456 Copier
DISPLAYING ADD TONER AFTER ADDING NEW TONER
Check your developing gear maybe one already worn out replace one set 5 pieces if not try re-install toner cartridge twice, check sp mode -toner drop or reset. hope this may help you.
Jun 19, 2015 | Ricoh Aficio 1013 All-In-One Laser Printer
I have a problem with toshiba e studio 181: i've changed a new toner cartridge but the indicator of toner is still flashing, and the machine didn't give any acces.
first check if the cartridge is original usually "have a serial & par code"
& Shake it will & clean carefully the green ship at the end off cartridge
check if the cartridge is already opened
turn the cartridge upside down " open the wight square tab & turn the Shield the Opposite Hand
[ check if broken ] while turning it .. you must see tone Flipping or moving at the square tab window
if not that's mean shield broken
try to fill its toner to an empty cartridge..
Jul 06, 2011 | Toshiba 1360 Black and White Copier
My copier sharp5316 has error code of f2 pls help me on this.
That is normall a defective developer unit chip, you may have to replace the chip on the developer unit or the developer unit itself.
Aug 17, 2010 | Sharp AR-5316 Advanced Digital Imager...
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
May 23, 2008 | Sharp AR-M237 Copier
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
Sharp AR-M355N Copier Logo
994 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
