Question about Maytag Refrigerators
I have a Whirlpool MFI2266AES and few days ago the ice/water dispenser stopped working. At the same time the freezer temprature started to rise and the temp alarm started beeping. The freezer fan was not running but started running again once I unplugged and replugged the fridge and the temp started to go back to normal. However, the water/ice dispenser still did not work. This has happened twice in the past few days and I can't help to think the two are related. Any suggestions?
Posted by winterlee on
ptpumpman
    Fixya-Fanatic:
    Visited the website for 90 consecutive days.
  • 408 Answers
Hi, it sounds like your having problems with the thermostat ,they don't last for ever. I had the same problem with a fridge freezer and i got the temp thermostat replaced. You have a modern unit and you may have two but i think you have to look at the ice cube maker side first. Check that the water supply is getting to it.Have a look at your manual or you can type in the make and model and look up online .
Posted on Mar 06, 2014
5 Related Answers
Anonymous
  • 19 Answers
SOURCE: ice dispenser not working, temperature display off then on
The auger motor gear boxes may also freeze they are exposed to extreme cold temps in the past i have removed the auger motor and derosted it with a heat gun not guaranteed but worth a shot
Posted on Jun 23, 2009
gaberdine
  • 13 Answers
SOURCE: freezer works, fridge doesn't cool
Probably excessive ice in the condensor. Likely defrost thermostat or defrost heater problem.
What happens is excessive ice keeps airflow from the refrigerator part of the unit.
Posted on Jul 09, 2009
Anonymous
  • 9 Answers
SOURCE: freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Anonymous
  • 4 Answers
SOURCE: water dispenser not working no water. ice stopped
If both stopped at the same time. Check the water control valve in the back of the refrigerator. Make sure the wires are connected and have not become loosen.
Posted on Jan 31, 2010
geoff hunter
  • 4793 Answers
SOURCE: freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Posted on Feb 06, 2010
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works, fridge doesn't cool
Jul 08, 2009 | Refrigerators
10 yr old Frigidaire ice maker stopped making ice
try forcing the cycle by manually triggering the cycle a few times. Sometimes you can detach the trip arm or turn the tray by hand by disconnecting it from the gear. There may have been a switch bumped to turn it off or the switch somehow jammed. Maybe check for freeze-up. If there is water in it, it's going somewhere.
Sep 27, 2008 | Frigidaire FRS26R4A Side by Side...
GE SIDE X SIDE Dispenser problem
Sound like maybe a dispenser board short... you could try taking of the top hidge cap on the freezer side unplug the power to the board there for 30 minustes or so plug back in and see if it can reset to default and try that before u have to change board
Aug 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
175 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
