Question about Kingston Electronics - Others
Kingston Data traveller USB password reset
Hi My parents have got a Kingston Data Traveller USB, but the silly sod has used up his attempts of the password, and now it wants to format, is there a way to reset so he can enter his now remembered password into it. He was given it years ago from a friend, so it was not registered to him. any help much appreciated cheers.
Posted by Gavla on
Mike M
  • Kingston Master
  • 3,324 Answers
Not knowing the model # makes it difficult to give you a difinitive answer. Kingston's support docs all say that after x mny failed logins the device will have to be formatted.
The default # of failed logins seem to be 10.
I think you're out of luck.
Posted on Feb 05, 2019
5 Related Answers
Anonymous
  • 63 Answers
SOURCE: pen drive not been detected by laptop.
try making sure that your windows drivers for your usb ports are up to date and installed via microsft update then restart computer and reconnect your thumbdrive
Posted on Mar 15, 2009
Anonymous
SOURCE: My DT100/4gb data traveller (kingston) pen drive is not working.
when i duble click on my pendrive icon it shows please insert a new disk. and it even doesnt open up
Posted on Jun 07, 2009
Anonymous
SOURCE: I had problem with imation lock
how format flash imation 8 gb write protected
Posted on Jun 16, 2009
Anonymous
SOURCE: how to create partition of kingston pen drive
format your pen drive with windows xp setup cd.
Posted on Nov 23, 2009
parasgumbhir
Paras Gumbhir
  • 179 Answers
SOURCE: kingston data traveller can't be found in my
go to this link http://www.softwarepatch.com/utilities/kingston-traveler.html
Posted on Sep 10, 2010
How can I retreive my files from a kingston 4GB DataTraveler
plug the 4kg data traveller it into a USB port open windows explorer open the data traveller select the files copy and paste into my documents on your computer
hope this helps
Aug 08, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston 8 gb data traveller suddenly became skymedi storage device.i cannot access it. can anybody help? thanks.
try maybe it is bricked or damaged, try downloading Pheonix products which can help u repair any usb damaged storage media, worked on my 8gig usb and nokia n95, or u can try googling flashing utilities for you flash
Oct 07, 2009 | Kingston flash memory card - 256 MB -...
USB 2GB KINGSTON DATA TRAVELLER HANGS MY LAPTOP
USB KINGSTON CAN'T ACCESS TO MY LAPTOP.HOW CAN SOLVE MY PROBLEM.
Mar 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
8GB Kingston Data Traveller only has 101mb available!
Hi Cristina,
This is Azeem Inam. your data traveller does not accept data over 101MBs. There can be two reasons for this problem. 1. there may be a virus that has provided a limitation on the copying facility. 2. This can be a partition problem. All you need to do is to use the software called DM (Disk manager). This is a DOS versioned software. Go into its advance installation option and then accept the hard disk kingston data traveller. It will take you to another menu showing the partition styles you may choose. you'll have to choose FAT32 type. then in the next menu you'll have to choose partition size by pressing enter button. and then accepting format you are done. it will start working as new again. Thanks for consulting your problem.
Feb 13, 2009 | Kingston Technologies 512MB DataTraveler I...
I don't know how to save to the kingston 4GB USB2.0 data travelter - no instructions with it
You just plug it into a USB port and your computer will automatically detect it.
Please rate this solution and thanks for using FixYa
Jan 06, 2009 | Computers & Internet
How to create partition of kingston pen drive
Nov 28, 2008 | Electronics - Others
Need a new kingston traveller secure software
I bought a new kingston traveller pen drive with the locking software, I installed it and after deleted the software unaware, now I can't go into my private partition.
Aug 29, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My kingston 2 GB USB Data Traveller does not wotk with windows 98
Your USB Data Traveler needs a USB version 2.0 driver. Try tofollow this link and install USB 2.0 driver: http://www.softwarepatch.com/tips/usb2-driver.html
Apr 21, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
MFC application in kingston data traveller encountered problem and needs to be closed
how did you try to format ?, try to unistall the driver when complete put the drive back in usb port. if that doesnt work keep the drive in port and open my computer right click on your thumb drive and go to properties click on tools and try error checking. this is probably where you try to format. once test is done pull drive out and reboot then put drive back in
Feb 27, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Electronics - Others Logo
219 people viewed this question
Top Kingston Electronics - Others Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
