So you need another bulb correct To order replacement lamps directly from The Sharper Image, call 1-800-344-5555 and order item number SI922. Lamps are effective for about 12 months of continuous use.
Hello, Sharper Image annoyingly did not carry this anymore. However, I found the replacement bulb at www.interlight.biz. They have any sort of specialty lamp / light bulb /projector lamp you can imagine. Here is the link for the lamp: https://www.interlight.biz/light-bulb/SHARPER-IMAGE-S1503
Look through the settings to see if there is a reset option for warnings or for lamp warnings. Many products with lamps require you to not only replace the lamp but to reset the warning.
The Spectrum is no longer being manufactured/distributed by EcoQuest (now Vollara). We don't have extra bulbs in stock, either, but we can try to locate one from another dealer if you'd like. email us at [email protected]. We've been with the company 20+ years.
Cleanwater also has them. Clean them with rubbing alcohol, do not let your fingers touch the bulbs. And check your 24V ac adapter. If it starts going you will get a power light but the other lights will come and go. I have one and the bulbs are nearing the end of life, not a cheap fix.
http://www.cleanwaterstore.com/O1002250-p-clearwater-tech-parts.html
I can give you some possibilities. A loose connection, a broken or corroded wire and/or terminal end, dust or moisture on a circuit board, the plate needs cleaning, the contacts for the plate need cleaning, the bulb ballast needs to be replaced, the bulb may not be properly installed, the support posts for the plate need cleaning. These are all I can think of at the moment.
