Check the info button in service mode. it will tell you all the possibilities for all ecode occurences.
Most likely a problem with your fixing drawer connector
It might reset and go away, or you may have to change connector
E004 0205 05 Title Thermistor temperature difference error Description of detection Difference of detected temperature between thermistors is bigger than the specified value. Measures 1. The connectors of the fixing main/sub thermistor (THM1-1 to 3) are physically removed (the cable is caught, or disconnected) -> replace the fixing belt unit 2. Check the rotation of the fixing motor (the connector is physically removed or disconnected) -> replace the fixing motor or the harness3. The connectors of the pressure sub thermistor (THM2, 3, 4) are physically removed (the cable is caught, or disconnected) -> replace the thermistor or the presure stay 4. Disconnection, soiled, improper location of, or faulty pressure sub thermistor -> clean the thermistor or replace it5. Faulty drawer connector -> clean the drawer connector or replace the fixing drawer cable6. Replace the DC controller PCB
Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
I will try to help you:
If any error code appears on the display or there are other
malfunctions, proceed as follows:
1. Turn off the power switch for a minute and then
turn it on again.
2. Insure the tether key is properly inserted.
3. Insure the power cord is properly plugged.
4. Insure the treadmill is properly lubricated (see 4.3.
LUBRICATING THE RUNNING DECK).
5. If the error code does not disappear after the
above mentioned maintenance actions, please
contact your local TUNTURI dealer. Always give
the error code and serial number (see the sticker
at the back of the frame, below the left-hand side
rail).
4.3. LUBRICATING THE RUNNING DECK Please apply teflon by using the pressurised can provided with these instructions. 1. Let the treadmill run at a slow speed and spray teflon into the lubrication . 2. When teflon is applied for the first time, E.CUADRA MANAGUA, NICARAGUA. C.A.
