SOURCE: How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
SOURCE: UPS Thermal 2844 Connection problem(USB)
Add the printer as a Local LPT1. Then go into the properties and switch the port to a USB port. Try a test label. If it doesn't print, go back to properties of the printer and switch it to another USB until it does. If all else fails there is a remove utility included with the Zebra drivers you downloaded. You can remove all zebra related drivers and printers and then reboot. The PC should redetect the printer when you turn it on.
SOURCE: how to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
