This type of error is generally caused by interference on the telephone line, an incorrect telephone line connection, or an alarm system or other device on the line.
1) Try re-sending.
2) Try connecting the machine to another phone line.
3) Have the line checked.
You did not say if this was a newly occurring problem. Regardless, take a look at this setup procedure but if you don't have a user's manual, contact Brother's support before altering setup:
http://support.brother.com/g/b/faqend.aspx?c=au&lang=en&prod=mfc7362n_as&faqid=faq00002728_005
You might try the chat or email at the support site as well.
Contact Brother
SOURCE: Busy signal on sending and recieving
Did you plug a phone into the phone jack and see if there is a dial tone?
Thats the first place to start.
After that let me know, and I will give you more ideas.
Sounds like a phone line issue
SOURCE: UX B700 Sharp Fax machine send fax issue
here is the manual
http://www.sharpusa.com/files/fax_man_UX_B700.pdf
good luck
SOURCE: can recieve well, sends all black
The scanner is not receiving light. That is either because paper is covering the scanner, or the scanner light source is not working. In this case, make sure the connections are in place, if so, replace the scanner.
SOURCE: How can I test that my fax machine can send and
Use the fax to make a copy if the copy is bad the fax you send will be bad.
DickyO
