Does it go all the way in and just doesn't turn on? Is the battery charged? Does it fit on the charger? Are the connection pins inside the camera bent? Check these then come back.
The serial number on a Panasonic HC-V800 camcorder is usually located on the bottom of the camcorder, near the battery compartment. It is typically a series of numbers and letters that is engraved or printed on a sticker.
Here are the steps you can follow to locate the serial number on your HC-V800 camcorder:
Turn the camcorder upside down so that the bottom is facing up.
Locate the battery compartment and look for the serial number near it.
If you are unable to find the serial number on the bottom of the camcorder, you can try looking on the side or back of the camcorder. It may be located near the connections or the memory card slot.
I hope this helps! If you have any further questions or if you are having trouble finding the serial number on your camcorder, don't hesitate to ask.
PanasonicNov 15, 2012 - Owner's Manual. Digital Video Camera. Model No. HC-V10. HC-V10M. HC-V11M ... You have purchased one of the most sophisticated and ...
PanasonicOperating Instruction Manual ( Multi ) - HCV10. FAQsFrequently asked questions about your product. What should I do if my product needs service? ... How am I able to turn off the time and date display on my camcorder? ..... LENS (ILC) POINT AND SHOOT DIGITAL CAMCORDERS LENSES ACCESSORIES · HOME HOME ...
Basic Operating Instructions Digital Video Camera HC-V10 Model No. Before use, please read these instructions completely. More detailed instructions on the ...
Sir,
the charger must be tested, if it not giving the out put voltage, you have to change it, check the connecting point for possible loose contact or corrosion inside the jack.,clean it.
How do you know the battery is actually "fine"? Did you put a meter on it or have you tried another battery? The battery can show to be charged but not working if it's gone bad.
Also, try removing the battery for at least 60 minutes, check and clean the contacts on the battery and in the camera, then install the battery and see if it will start. Sometimes removing the battery for some time will reset the camera.
a technician ' s adjustable bench power supply -
set for 9 volts at 1 amp - for a minute or so ,
will initialize most new lithium batteries
( a charger update may also be available ) ;
