HOW DO YOU GET THE DOOR OFF?
There is usually a plastic part covering the top hinge. It will pull or snap off, rarely there might be a small screw.
Remove that plastic covering, and then unbolt the part of the hinge assembly attached to the body of the freezer.. DO THIS WHILE THE DOOR IS CLOSED! That is so the magnetic seal around the door will tend to hold it in place. Lean against it as you remove the hinge part so the door does not fall away and land on you, or even worse: break the door!
Slowly lift the door out of the bottom hinge, and carefully set it somewhere safe.
Be VERY CAREFUL when you set the door down. If you set it upright, against a wall or something, be aware that there is a pin sticking out the bottom of that door hinge, and it will likely simply ruin any flooring you set it on - and I speak that as a "voice of experience"!
Have fun!
