Question about Philips bSure SV1 Multimedia Projector
Philips bsure SV1 , LCD multimedia projector
As we use Lcd projector of philips (model -Philips bsure SV1 , LCD
technology , brightness 1200 ANSI LUMENS, SVGA,
LAMP LIFE UPTO 6000 HOURS) in our school and college. Purchased from Gayathri Technologies , 5- Bimla bhavan,Nagardas cross road, Andheri (E) , Mumbai - 400069.on  07/08/2002
SERIAL NO WR02022561002427
In year 2004 the Lamb of the projector has been replaced with another new lamb. Now its started again grating problem :-
AFTER 45 MINUTES THE PROJECTOR TEMPERATURE RISES  IT STOP WORKING. WHATWE SHOULD DO. GIVE ANY SERVICE CENTER PHONE NUMBER FOR SERVICING.
ASI TRIED OLD NUMBER OF OFFICE . BUT NO RESPONSE WAS THERE. SO PLZ  IREQUEST TO GIVE PROPER SUGGESTION WHAT TO DO AND YOUR CURRENT WORKINGPHONE NUMBER OR MOBILE NUMBER OF SERVICE CENTER  TO WHOM WE CAN CONTACTFOR SERVICING.
Posted by savita on
Anonymous
Pl try M. R. nterprises Mumbai +91 22 23802513/23856204
Posted on Nov 25, 2007
Why projector takes time whe it is started
Depends entirely on what you mean by "takes time". These projectors require a few minutes to reach full brightness, and many models even activate an LCD shutter to black out the image until the lamp has reached reasonable brightness.
If you mean it takes several minutes to produce any picture at all, it may just be time to replace the lamp, as it may not be striking (starting the lamp) correctly due to a fault in the lamp starter circuit or the lamp itself. In the absence of a detailed fault description, my best guess is that it's most probably a tired lamp :o)
Apr 07, 2014 | Philips bSure SV1 Multimedia Projector
Yellow blur on screen
Blue LCD (from RGB ones) is either dirty or burnt. Google how to DIY exchange it.
Dec 06, 2010 | Philips bSure SV1 Multimedia Projector
Tried to download the manual for a Philips bSure SV1 projector but its just a 2 page spec document. I need the full manual. Just for your information.
Go here
http://www.usersmanualguide.com/philips/monitors_and_pc_peripherals__office_projectors/lc3131
and download third file.
Sep 14, 2010 | Philips bSure SV1 Multimedia Projector
If the Standby button is red, press it once to start the projector. Otherwise read page 33-34 of the Manual.
Sep 23, 2009 | Philips bSure SV1 Multimedia Projector
No yellow colors
first reset all the settings to factory default, then try a different cable. if problem persists, one of the lcd panels, the polarizer lenses, or the main board is bad.
Sep 09, 2009 | Philips bSure SV1 Multimedia Projector
Philips bsure sv1 projector
press menu, then picture, select mirror, then choose the "Aa" which appear to be the right way up for you, then press ok.   Done!!
Oct 04, 2008 | Philips bSure SV1 Multimedia Projector
Philips bsure sv1
in the menu under setup or service look for orientation. I don't know this menu but it should be an option to "reset" the projector to factory at the very minimum good luck
try plugin a computor or dvd in so it picks up a signal.
Dec 15, 2007 | Philips bSure SV1 Multimedia Projector
Philips Bsure sv1 lc3131
This indicates the bulb has blown and needs replacing.
Jan 14, 2007 | Philips bSure SV1 Multimedia Projector
Philips bSure SV1 Multimedia Projector Logo
226 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
