Question about Xerox WorkCentre M123 Copier
Xerox workcentre xd105f
I'm getting a L6 code, and having a hard time finding anything on the web that might help me fix the problem. the only thing I've found is it has something to do with the polygon motor, whatever that is. can you help?
Posted by panzeca on
  • Anonymous Dec 05, 2007
    I have a xerox XD 105f that is about 4 1/2 years old. For about the last two months the L 6 sign flashes intermittently. The instruction book says to turn the power off and then back on which I do. Usually that works, but it is occurring more frequently and I am afraid that it willl break down soon.
    I want to know what is wrong with it and whether it is worth the cost of paying a tech to come out and fix.
    What would be the broken part and how much to replace?
    thx
  • Anonymous Feb 05, 2008
    I a
Rick Kasper
    President:
  • 2,072 Answers
Guest.
The L6 indicates the machine is not seeing the motor in the laser, that rotates the mirrors.
There are 3 possibilities, I will list them in order of probability.
1 The Laser unit itself.
2. The cable connection on the Main Board.
3. The Main Board itself.
The laser depending on the lens, Curved or straight is $323 and $393.
the main board will cost in the $250-$400 range depending on the vendor.
That is without labor.
Posted on Jan 03, 2008
Anonymous
I have a Xerox Workcentre 105f B&W copier.
this copier prints the right copy on the left handside and the right hanside on the left.
this problem happened since I sprayed compressed air to clean the black powder from the ink toner compartment in this copier.
no erros code signal.
any idea what is going on?
Thanks
Posted on Feb 05, 2008
Anonymous
    Novelist:
  • 208 Answers
L6:The Main PWB sensed a Polygon motor lock signal error.
5-L6 only: Check the connector CN23 on the Main PWB and the wires and connectors on the Laser Module. If connector and wires are not damaged, replace laser module
Posted on Nov 28, 2007
Anonymous
    Scholar:
  • 53 Answers
L6 on Xerox usually means an external device (like a coin unit) is disconnected, well it wouldn't be that! another L6 is the xerox plug in card supplied with toner/ drum units which maintain a count of copies done on that unit Not familiar with particular model as model numbers change in different parts of the world (I'm in Australia) your model may not have that feature...did it just happen, or did you change something?
Posted on Nov 27, 2007
Need Drivers for Xerox XD105F for Vista
I see you are looking for a chat for this as I try to help you for free (what a nice guy am I!) ... I went to the windows 7 hardware compatibility list for your printer ... it says on page 21 there is no information available. I understand you are using Vista not 7. I went to Vista compatibility list ... no information available.
This is generally a nice way of saying your (who ever) device is no longer supported by the operating system and we (Microsoft/the manufacturer) are not writing a driver for it - it is time to upgrade.
So, there is your free answer ... I hope you got a better answer for your $20.00 chat ...
Thanks for using FixYa.com
Jun 03, 2011 | Xerox WorkCentre XD105F Laser Printer
L6 Code
The Laser's Polygon Motor has failed to reach proper speed in the allotted start up time.
Replace the polygon/laser assembly.
Jun 19, 2009 | Xerox WorkCentre XD130DF Laser Printer
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Need Drivers for Xerox XD105F for Vista - Do any exist and where
try this link > http://drivers.softpedia.com/progDownload/XEROX-Printer-WorkCentre-XD105f-501230001-Download-2253.html
on the right side there is a DOWNLOAD LOCATIONS
for XEROX Printer WorkCentre XD105f 5.01.2300.01: and below is EXTERNAL MIRROR, click this mirror and save the file. Scan the program prior to your installation, file size is about 4MB. Let me know if there is any other i can help. regards. cebuwano
Apr 11, 2009 | Xerox WorkCentre XD105F Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
L6 error keeps popping up
That is a laser error. The motor that drives the mirrors is most likely oing bad, The laser unit will have to be replaced.
Jan 30, 2009 | Xerox WorkCentre XD105F Laser Printer
Connecting printer
You can purchase an adapter "Parallel to USB" for printers to be used with printers.
http://accessories.us.dell.com/sna/productdetail.aspx?sku=A0489585&cs=04&c=us&l=en&dgc=SS&cid=30098&lid=674094
Hope this helps. Bud
Jan 09, 2009 | Xerox WorkCentre XD105F Laser Printer
Xerox XD100
I have a XD100 Work Center with a L6 error code indication. After press "C" Clear (orange color button), followed by "Auto" (the most left small button) - exposure mode key; and "C" followed by "Auto" again, the copier starts to print and solved problem.
Nov 02, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre M123 Copier Logo
1,102 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
