Question about Magic Chef MCWC44DZ Wine Cooler
Possible switch issue
I hear a clicking noise, the unit does not cool
Our intertherm furnance is clicking twice before the burner lights. Why?
If your unit has a spark igniter you'll hear clicking noises until the flame is lit. If it hasn't done this in the past, then its quite possible the igniter is starting to oxidize and needs to be cleaned. The best way to do this is use a light abrasive cloth to remove the oxidation, or otherwise known as soot. Sometimes, the igniter needs to be removed and as always remove power to the system before attempting any repairs.
Jan 22, 2017 | Intertherm Heating & Cooling
Hear no clicking when I turn on switch inside my unit, suburban water heater model sw12de. Could igniter be out?
Could be your igniter or possibly your control board. The red light not being on indicates you most likely have an electrical issue. Check your breaker as well. If you nee any parts this site will have them all
http://www.suburbanrvparts.com/
Jun 05, 2014 | Suburban Gas and Electric Water Heater, 12...
Will not get cold
Hi Ebony! Are you having issues with the unit turning on at all and staying on? Or do you not hear the unit turning on and running? If you hear no noise, to show the unit is running (compressor turning on), you would need to contact a professional at your earliest convenience. The compressor and sealed system are not turning on. If you hear the compressor running, but the unit is not cooling you have a coolant/sealed system concern. Please contact Frigidaire and a professional to repair the unit.
Sep 04, 2013 | Frigidaire Freezer GLRT183TD
Refrigirator stop cooling
if you hear a noise like clicking when the compressor tries to start and unit will not cool the starter overload on the side of the compressor that starts it has burnt out simple replace the starter overload and it should start
Apr 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
RAS7233KQO fills and agitates but then will not drain, rinse, or spin
1 of two possible issues, either you pump is clogged, you would the hear a buzz and possible smell a burner smell while the unit is running, or 2 you have a broken lid switch....open and close the lid slowly and see if you hear a click, if not you lid switch needs to be replaced.
Jun 09, 2009 | Roper RAX4233PQ Top Load Washer
Does not cool. Compressor Hot
Sounds like the compressor starting relay. This should be available from from most appliance parts retailers that carry refrigeration parts. It is probably a plug-in relay which is easy to replace. PULL THE PLUG UNTIL YOU GET IT! Constant cycling on the thermal protector will damage the unit.
Ray
Oct 19, 2008 | GE PWR04FANBB Wine Cooler
Magic Chef MCWC44DZ Wine Cooler Logo
Top Magic Chef Furniture Experts
Sheldon Dedek
Muntejaya Ginting
Muntejaya Ginting
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
