Question about Nor-Lake Refrigerators
What does P1 error code mean?
P1 error code with Dixell controller?
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: P1 error code on LX30 Hobart
This is a bad sump temperature probe. The unit will function, but will not heat nor display the wash water temperature.
This is a very easy fix. Order Hobart part number 328994 from your nearest Hobart parts dept.
Turn off and drain the unit. Kill the power to the unit at the circuit breaker. Remove the lower front cover. Locate the screw-in temperature probe at the front of the sump. Unplug the sensor from the wiring harness, remove with a 7/16" open end wrench. Screw in the new probe, using teflon tape of the threads, snuggly. It does not need to be super tight. Plug it into the harness, reinstall the front cover, turn the breaker back on, and start up the unit.
TURN THE BREAKER OFF AS EVEN WITH THE UNIT "OFF" THERE WILL BE 120 VOLTS PRESENT AT THE SUMP HEATER (yellow wires) DUE TO ONLY ONE LEG OF POWER BEING SWITCHED OFF!
Posted on Sep 12, 2009
Testimonial: "You were right! can you help mr with a P2 error code?"
Gordon Benson
  • 83 Answers
SOURCE: What does error code P1 mean?
Hi Mike
P1 is air probe faulty
Regards
Gordon
Posted on Apr 20, 2011
Jonathan James
  • 75 Answers
SOURCE: my ducted air conditioning has an error code on
Hello
Check that the filters are clean and check that the sensor is still in place if all is check and still gives error code then the sensor is faulty.
Thanks
Posted on Jun 04, 2011
panza83
panza83
  • 15 Answers
SOURCE: What does P1 mean
t appears to mean "defrosting." In other words, the condenser coils have gotten too cold and are icing up..
The filter is probably full, or the thermostat is faulty. Open it up and clean the filter first.
Posted on Sep 17, 2012
Bigeasy
  • 5 Answers
SOURCE: I get a P1 error
just clean shower head or faucet with CLR to increase water flow. I have same problem
Posted on Oct 24, 2012
Need help with dixel control
http://www.emersonclimate.com/Documents/Retail%20Solutions/XR35%20Manual.pdf
Dixell
The first link is to a specific manual. The second is to the Emerson Dixell site where there is support and resources. If the site does not provide what you need, try googling by brand plus model plus troubleshooting.
Jan 06, 2018 | Televison & Video
P1 light stays on. I even unplugged the unit for a day and it still shows P1
Hi Marilyn,
I've just searched for "error code p1 perfect" and the second hit was on fixya in June 2012. Have a look and see what I mean. The easy way to find answers for every product question Just Ask
Jul 29, 2015 | PERFECT AIRE Dehumidifier PA65
Blue star Visi cooler subzero error code p1
Amazon.com: Questions And Answers: WHAT DOES THE P1 error code mean??
www.amazon.com/.../ref=ask_dp_dpmw_al_hza?asin...
Amazon.com, Inc.Oct 19, 2014 - Hi David, According to the manual: "P1- Unit is defrosting-- Allow the unit time to automatically defrost. The error will clear after the unit self ...
Jul 26, 2015 | Dehumidifiers
2004 rodeo fault codes 1520
P1520
no U, not B, not C codes.
need the full code.
not truncated. please.
here ill google for you, P1 codes can be wrong, as p1 is factory only code.
Possible causes
- Faulty Throttle Valve Motor
- Throttle Valve Motor harness is open or shorted
- Throttle Valve Motor circuit poor electrical connection
now how to google
ill type for you....
https://www.google.com/webhp?gws_rd=ssl#q=isuzu+p1520
most of what you find in google or here are rumors
why not read the FSM and avoid those errors.
rumor or false data.
alldata.com
log in and read.
see all P1 errors that match your car, your engine,etc.
what they mean
what test to do , to find true cause are in the factory manual.
Oct 13, 2014 | 2004 Isuzu Rodeo
What does a P3 code mean? On a Hobart LXI high temp
P3 code refers to the probe near the airgap at the back. It is monitoring the rinse temp. P2 is the booser probe, and P1 is the wash tank. The control board will store error codes, so once changed, you can access the memory and clear it.
Jan 05, 2014 | Dishwashers
What does P1 mean
Sep 17, 2012 | Midea MDF1-30AEN3-BA4 WP 30PT ES...
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
My Whirlpool AD40USL5 Dehumidifier is displaying P1 on the control panel. I am not able to find any information about this in the User Guide that came with my unit. Could you please tell me what this...
Here is a link to the Owners Manual for the model number you listed. However, it does not have a LCD display on the Control Panel, which would show the Error Code P1. This is a Kitchen Aid brand that was manufactured by Whirlpool with the AD40USL5 Model Number. This came directly from Whirlpool's website. Hope it helps you in some way.
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201187730.pdf
Apr 04, 2011 | Whirlpool AD40USL Dehumidifier
Have a p1 flashing on the remote control and no hot water. I have tried shutting the water and power off and still a p1 flashing on the control unit.
P1 is reportedly defective check valve that can cause water flow to decrease, and tankless not heat water smoothly. But can also be other causes, or combination of causes. Call service technician, contact Rheem, or replace check valve and see if problem solves. Then add a comment with solution so others can benefit from your experience.
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 13, 2011 | Rheem Water Heaters
Why get a P1 error code on my Rheem tankless RTG-64xp?
1) I cannot find Rheem error code P1
http://www.palomatankless.com/owners/homeowner+trouble.lasso
http://www.palomastore.com/paloma_error_codes.html
2) BOSCH does not show P1 either:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
3) Best I could find is that folks with P1 error code report tankless fires for short period, and then turns off.
This implies air, fuel or vent problem, and can be internal, external or combination.
4) P1 appears frequently on control board descriptors, which might imply the error is control board malfunction.
5) Call Rheem 1-800-432-8373, and then add a comment to this thread and let folks know what you discover.
6) I will also call Rheem when time permits, and post what I discover.
Add a comment for more free help.
Mar 05, 2011 | Rheem Water Heaters
Refrigerators Logo
1,012 people viewed this question
Top Nor-Lake Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
