SOURCE: If I buy 2 12
two amps and get a 2 farad cap please because if u dont u could melt wires together cause a fire or toast ur alt.
SOURCE: Complicated JL Audio Amp
1. set the amp LP filter frequency at about 80hz and mode/slope to 24db.
2. set the amp gain as recommended in the manual.
3. set the subsonic to on and to about 25hz
4. ste the bass eq to off!
5. set the input voltage to low and signal sensing to off
6. Fine tune by ear.
SOURCE: jl audio w7 13 subwoofer system 3ohm driver bridge it 2 ch amp
How much is your speaker max wattage?
If it is 750 or below, it can only be used on one channel, either the right or the left.
If speaker can handle 1500 watts then hook the positive speaker wire to R+
Hook black negative speaker wire to L-
Now it is bridged
SOURCE: i got a jl w7 12 in a seald box runnin it with a
try looking @ your amp seeing if it is bridged if it is take look @ this video it might help you.
