Hp photosmart C6380 all-in-one wireless printer
Not quite sure we got the complete message there- but here goes., You've recently changed routers and now your networked printer is no longer connecting to the network.
1.) remove the driver from your Pc
2.) turn on printer- when ready press menu button , use the arrow keys to navigate and the print switch for enter - select SETUP, then I/O connections/networking, then select Auto-IP enabled, Boot DHCP.
3.) turn off the printer, wait 10 seconds, turn on the printer allow to come to ready
4.)n reinstall the driver, it should search automatically for the printer.
SOURCE: Problem for HP Photosmart C6380 All-In-One InkJet
It's probably telling you it is out of ink.
The ink system can fail if the cartridges in the product are installed
incorrectly, if the ink in the cartridge is low or out, or if the
cartridges are damaged or not correctly vented.
Here's the HP page that details the solutions for this problem:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&cc=us&lc=en&dlc=en&product=3560280
SOURCE: wireless printer won't print
This is usually caused by the Printer being set to DHCP, which allows the router to change the IP address of the printer. When you setup the printer, it set to a specific IP address. Try reconfiguring your printer to a static IP address with the last octet 3 values beyond what your current computers IP address is. As an example, if your computer's IP address is 192.168.1.3, make the printer 192.168.1.6. That should keep it clear from any additional devices you attach to your router in the future.
You will then have to go into windows and add an additional port for the printer with the new IP address, the example above is 192.168.1.6. Good luck! :)
SOURCE: MY PRINTER OFFLINE
I don't have a solution for this problem. I have a comment. I have the same types of issues with my HP. I hate HP. Why is it that we can design software to remotely fly fighter jets but we can't get reliable software to print wirelessly? I am now going to throw my HP Photosmart C4580 All-in-One in the road.
