Question about Akai LCT3201AD 32 in. LCD Television
Akai lct 2701 sound does not work
My tv's sound died. There used to be a high pitched sound when turning the tv on. Then the sound would go off. To get the sound back on I would change the sound settings, then I'd have to change the picture brightness to a dark setting, finally when those 2 methods didn't work I'd have to unplug & reset the tv. Now none of these methods work. Is there a sound card or something that is easily replaced?
Posted by John Ruane on
2 Related Answers
Jaime Hernandez
  • 2337 Answers
SOURCE: Akai LCT 2701 TD - Red Blinking lIngt
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Posted on Nov 26, 2008
Chi Chu
  • 8457 Answers
SOURCE: I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
Posted on May 07, 2010
AKAI LCT 2060 was working well as a TV. Just hooked it up to my PC and the message on screen reads "No Signal" Checked monitor cable and it's good. checked old monitor and it works well. Why...
The display settings on your computer need to be turned down. Set it to 800x600 and move up from there, if the resolution is too high - the TV won't display it.
Feb 28, 2011 | Akai LCT2060 Television
May 07, 2010 | Akai LCT2060 Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
LTV-2701 27" LCD HDTV
The problem with your TV is because the power supply is weak and will need to be repair or replace.
I repair these power supplies, let me know if you need further assistance.
Nov 05, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Akai LCT 26AE Universal remote codes for RCA remote
i cannot find the model # to my akai tv/dvd combo where is it? AND ALSO I DO NOT HAVE THE REMOTE TO IT LOST IT DURING MY MOVE. HOW CAN I PURCHASE I NEW REMOTE OR WHICE UNIVERSAL ONE SHOULD I BUY! PLEASE HELP
Nov 02, 2008 | Akai LCT2715 27 in. LCD Television
Jul 08, 2008 | Akai LCT2701TD Television
Astar LTV-2701 27
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected] if you require further assistance.
Jun 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Akai LCT 32"
Do you still have this TV?Sounds to me like a bad capacitor,or two.I just got done fixing an Akai LCT2660 that had four bad capacitors on the power board.Works perfect now.Hope this helps.Thank You very much!
Tyler
Jan 03, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Akai LCT3201AD 32 in. LCD Television Logo
22 people viewed this question
Top Akai Televison & Video Experts
Marvin
Marvin
matt martin
matt martin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
