The face for the dispenser has turned yellow and I want to paint it along with the handles. I got the handles off just need to know how to take off the dispenser face or cover.
Breakable. Leave it on and place tape/paper, etc, around it and spray paint. May need to lightly sand to remove finish AND then prime to make paint adhere sufficiently OR use a paint with bonding agent/primer in it.
Because "home" painting is not same process as factory finishes, it may have to be done periodically to achieve/maintain desired look you want.
SOURCE: how to repair the ice dispenser door on a whirlpool refrigerator
If you will look on the bottom of the dispenser cover you will see 2 notches on the left and right side. carefully pry the cover off using a flat tip screw driver. then you will see a white switch plate that is either held on with latches or 2 srews depending on model. once this is removed you will gain access to the dispenser door.
once you gain access I think you will find the hinges for the dispenser door are broken off. if so you will need a dispenser door repair kit form whirlpool part # 8201756 this kit includes new door and hinge repair kit. this is something you can do yourself if you are pateint and pay lose attention to detail. otherwise I would recomend a god servie company. thanks for using FixYa Peyton
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Had the same problem. Pressed button heard a click, saw zeroes flash, then nothing. After some online search I found and solved the problem. Corrosion and condensation on the connector plug attached to the wire at the bottom of the freezer door. Remove plastic grill, pull out wire from under box. You'll find a plastic connector and possibly wet or corroded wiring. CUT POWER TO FRIDGE OFF FIRST. I cut away the white plastic connector then stripped and tied the wires together with wire caps. Taped them up too. Note which wire goes to which first. Mine was blue to blue, black to black, and red to white. Problem solved.
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
You can get
required parts from online sites like:
--- www.repairclinic.com or from searspartsdirect online site.
----------- This should help.
Thanks.Helpmech.
