Question about Xerox Printer Division Xerox Phaser 7800/GX Tabloid-size Color Printer
How set factory default xerox 7800 - Xerox Printer Division Xerox Phaser 7800/GX Tabloid-size Color Printer
Posted by Alex Morgan on
dann jackson
  • 78 Answers
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen whow set factory default xerox 7800 - 7800-ts-tools-setup-service-tools-reset-nvram.pngmages/7800-ts-tools-setup-service-tools-reset-nvram.png" alt="7800-ts-tools-setup-service-tools-reset-nvram.png" class="h_mi" how set factory default xerox 7800 - 7800-ts-tools-setup-service-tools-reset-nvram1.pngin.
Related Knowledge Bases:
Posted on Mar 29, 2014
Xerox phaser 7800 rebooting all time
Most likely cause is corrupted software which requires an alt boot which requires the Xerox laptop to reinstall.
Apr 09, 2016 | Xerox Office Equipment & Supplies
How to reset a Xerox Workcentre Pro 123 to factory settings?
The default userID is 11111, and the default password is x-admin http://www.office.xerox.com/userdoc/CC_WCM_WCP_123_128/CC_WCM_WCP_123_128_Web/pdfs/Quick_Networka_Setup_En.pdf
this guide should let you set dhcp and otherwise control it
I was unable to find a "factory reset" solution
Aug 03, 2015 | Office Equipment & Supplies
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
Set factory default
Go to the menu, look in setting and scroll through until you see factory default setting. The functionality you're looking for should be in this area.
May 02, 2010 | Xerox Phaser 6200N Laser Printer
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Mar 03, 2010 | Xerox Phaser 4500 Printer
Xerox Phaser 3200mfp Memory Issue
Do you have the receipt for the machine? You have a 1 year warranty from Xerox on that machine, Here is the copy and paste from the warranty information on the Xerox website.
Xerox warrants that the Phaser 3200MFP product and its Consumables, Routine Maintenance Items, and Options/Upgrades (related items) will be free from defects in materials and workmanship for the periods set out below:
Product: a period of one (1) year from the date of shipment.
Aug 21, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Apr 03, 2008 | Xerox WorkCentre M-24 Color Copier
Xerox Printer Division Xerox Phaser 7800/GX Tabloid-size Color Printer Logo
2,660 people viewed this question
Top Xerox Printer Division Office Equipment & Supplies Experts
Ekse
Marvin
Marvin
Are you a Xerox Printer Division Office Equipment and Supply Expert? Answer questions, earn points and help others
