No picture or sound and has a chirping sound
SOURCE: Please Help!
A chirping sound from a TV set is the switch mode power supply trying to start up, but gets shut down because of a major short inside the set or in one of the circuits.. Most likly in this set, the horizontal output transistor is shorted because of a defective flyback transformer. Thats whats the common problem is with this set. A repair like this, if this is the only parts that are bad, will run you about 300 to 400 bucks or so. In some cases, not many but a few times, I have seen poor solder connections on L401 cause the horizontal output transistor to go bad. There are no user replacable parts inside this set, so please play it safe and seek out a pro to assist you in this repair. Good luck PS Please do not forget to rate this thread.
SOURCE: No picture or sound - TV makes chirping noise
Rich that chirpin noise is somthing over loding it try checking your horzotal output for short and diodes around the transformer...
SOURCE: When plugged in, it makes a chirping sound.
hello it sound like 1 of the capacitors may blown or swelled up. with the power of you need to do a visual check of the board inside check for any burn't part i'e resistor capacitors transitors diodes any more info you need get back to me
regards
shaun
Testimonial: "Thank you for giving me somewhere to start looking to solve the problem."
