Question about RCA F27450 27" TV
Tv wont stay on whats broke in it - RCA F27450 27" TV
Posted by Robert Panholzer on
arcada
    New Friend:
  • 94 Answers
If it turns off in the same amount of time every time, and can turn right back on, check your sleep settings... it is a feature that turns the tv off for you.
Posted on Mar 05, 2014
What would be the solution if this tv wont turn on?
It seems there is hardware problem so i guess you need to take it to service center for the same, as there is no easy fix for the same.
Phone wont stay charged and wont stay on only when the charger is connected and then the red screen displays ftm mode what is the problem?
The first thing that pops intro mind is that your battery is broked. Have you tried using another battery of the same type?
May 06, 2011 • Cell Phones
My turn signal won't go off, it constantly stays on
there is whats called a cancel cam inside the steering column it is a metal ring that hits a plastic tab inside the wheel as it turns if its broke it wont hit the tab and wont shut off the turn signals
4helpful
It wont rurn on
replace capacitors c520 and c126 to get your power working again.
Also make sure that you don't have a broken green 3 inch jumper wire broke that lies under the heat shield in the top right corner. The wire should be glued to the board for stability. It sometimes breaks loose and will cause the TV screen to stay off.
1helpful
My viore tv wont stay on it keeps going off by its
Ur tv the projection lamp,inside the tv now,been on an in used about 4 or 5 hours a day,the bulb been inside tv about 1 1/2 or 2 years?The projection lamp life is over,reqiure changing?Turn tv on hear alot of clicking too?The board call the Ballast board also require changing too,this Ballast board help to ignite the projection lamp.
My tv broke that i had my converter box hooked up to so bought another one now i cant get a signal, my converter box wont stay on.
if it is hooked up through the componant, or composite cables, that is the red white yellow, or the red blue green red white, you have to take note of what input it is plugged into on the back of the tv, they are labled, then hit the input on the remote control to match the input your plugged into, even if your using the screw on cable, stioo have to put it on that input, also try turning your tv to chanel 3
Sony Wega wont go on
Hii....
When the " SONY Bliking Codes " generated the circuits self diagnostic to trigger the pulse because some error accure....5 times blinking mean there's something wrong whit RGB level,the level not balance after 2 second due at first time the tv on...the protection circuit will send the error report,the tv will have no picture or sound....you will need to check at M board there's much things you have to do...
Thanks
[Vrya]
RCA F27450 27" TV Logo
Top RCA Televison & Video Experts
 Francisco Mauricio...
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
