I have a Hotpoint TCL 780G condensor tumble dryer which was not heating. I have just changed the thermostats and the the dryer works again until I sevrew the back on and then it trips the electric! What have I done wrong!!??
SOURCE: no heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave www.washermd.com
SOURCE: Dryer runs, tumbles clothes, but does not heat
PSUinNC The first thing you have to do is to check in what position is the temperature switch . If the temperature switch is in the "air fluff" position, then the heater will stay "off". If this is not an issue, reset the circuit breaker. The motor needs only 120V to run, but the heater needs 240V and if one of legs is missing, the dryer would not heat. If it did not solve the problem, you have to perform full diagnosis. You will need some simple hand tools and a meter to check a continuity. If you are fillng you can handle it, let me know and I'll give you the step by step instructions. Gendos...post back
SOURCE: Not heating up
Hi
If your dryer doesn't heat, check these:
Power from the house -- Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element -- Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse -- On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring -- A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: Tumble dryer trips electricity
I own the same machine and this happened to me, if the internal working of the machine get wet it will cut off causing the electrics to trip. This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced. If water has built up in the machine you will also need to check to make sure none is sitting in the heater coil compartment (it did with mine) to get at this you will have to unscrew the metal plate at the back of the machine and let any water out. Leave the machine for a few hours to make sure it is dry and then give it another go. If your machine is still under warranty though i would call indesit first as they may get a little funny if you remove any of the machine covers yourself and refuse to look at your machine.
