Wire wrapped around roller is bunched up and one end is rubbing against structure
SOURCE: proform treadmill belt won't stay centered.
Adjust the tension on the right side rear using an allen wrench. Try 1/4 turn clockwise( should tighten). then run tread mill for 30 sec. to see if it centers itself. repeat again if not. if its to tight then turn the left side in a 1/4 turn
SOURCE: I've bought a Proform 900 Crosstrainer but it did
For the paper-version ($7.95), use this link:
http://www.online-owners-manual.com/pfccel45011.html
They don't offer a downloadable manual for the exact model, but offer a comparable model's manual here:
http://www.online-owners-manual.com/drel45010.html
Hope this helps!
-- RT
PS - Don't forget to vote!
Testimonial: "thanks for your time and info - much appreciated!"
SOURCE: Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
