Question about Dynex - 10-Sheet Microcut Paper Shredder
DX-PS10MC gear broken
Driving gear, on end of paper shredder assembly, right before driven gear on CD/card shredder. Hub cracked on plastic gear, need to replace. Rest of shredder is flawless. Dynex is only one brand selling this shredder, just can't find parts.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
Might have to go to eBay or Gumtree.
Posted on Jun 18, 2014
jyackle5
Jyackle5
  • 8197 Answers
SOURCE: Dynex shredder DX-PS05CC: purchased at
If it has been under 30 days take it back to best buy and tell them what is wrong. Then exchange it for a new one.
Posted on Dec 20, 2010
Staple stuck in shredder
First lesson - NEVER put staples through shredder. Have you been able to remove the staple? Switch all power off, and then look at blade section. If still present - remove staple - may need magnet or tweezers. This should fix the problem, but if it doesn't it seems you may have some teeth out of alignment. This will probably require replacing the shredder bar by a technician, or a new unit.
Mar 08, 2014 | Dynex Office Equipment & Supplies
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
RE; Durabrand Paper Shredder. Model Number WM6X. The motor works in reverse mode only, but the blades don't turn, Help
You have broken gears. Call customer service at 800-327-8508 and they will send you 2 gears for $10 including postage. I got mine in less than a week. Easy install.
Nov 05, 2009 | Office Equipment & Supplies
Royal paper shredder makes a thumping noise
They have plastic gears in them and are generally broken or cracked.New gears are avaiable from the manufacturer
Mar 24, 2009 | Office Equipment & Supplies
Paper stuck in the Fellows Paper Shredder
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Feb 09, 2009 | Fellowes DM8C Cross-Cut Shredder
Broken....
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 11, 2009 | Fellowes DM15C Shredder
Paper shredder
sounds like you probally have a broken gear on the drive portion of your shredder can't be more specific because I only have info on Fellowes brand shredders. You may have to contact manufacturer for more info.
Jan 26, 2008 | Office Equipment & Supplies
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
Dynex - 10-Sheet Microcut Paper Shredder Logo
221 people viewed this question
Top Dynex Office Equipment & Supplies Experts
graybeard32301
ray gallant
Tom Chichester
Are you a Dynex Office Equipment and Supply Expert? Answer questions, earn points and help others
