Delete/ or move some pictures from internal memory or if the camera has external memory set your camera storage option to external memory/memory card.
Good Luck
Digital camera internal memories are small. Put an empty sd card in, or delete the pictures from one so it is empty, then place it in the camera. Turn the camera on...
Now use the menu to find how to delete the shots you took before that went instead to the internal memory
SOURCE: transfering pictures from my memory card
when you connect your camera to the PC.
look in My computer and find the drive ( camera ) probably shows as Drive F:/ G:/ H:/ I:/ or similar.
Right click and open, then copy to folder on desktop, named My-Pictures ( Or similar ) once you,ve copied your photos from memory card to desktop on PC. Format the memory-card. which will erase all data. ( Right Click Format )
This should solve your problem.
Mike @ compurepair.
SOURCE: Internal memory is full
u go to menu -hit down to where it says auto -it will bring up auto and internal memory...hit internal...then u can delete your internal memory the same way u do on your chip..
SOURCE: I have a picture on
Find the function to transfer internal pics to memory card, refer to instruction guide or try to go through settings menu and explore.
Hi.
Enter main menu, scroll down to "Setup Menu" and then navigate to "FORMAT". Simply format your internal or external memory, and thats it.
SOURCE: Sony Digital camera model DSC 5730.How to delete all pictures.
insert new memory card lollll
What make and model camera?
