Hi there Can anyone tell me if the SH-FX71 wireless transmitter/receiver will operate on a Bluray Home Cinema system SC-BT205? The instructions indicate that SH-FX70 is the correct unit but that has been discontinued now and seems to have been replaced by the 71. However the specs for that do not list the BT205 as being compatible. I am thinking of purchasing the BT205 (used) to replace my now none operational DVD home cinema system, but I really want wireless rear speakers. Thanks Paul
It may be favorable to simply purchase a rear wireless speaker system all by itself and use the existing system for surround sound applications. Monoprice . Com has some units are a good price.
SOURCE: No sound from our Sony Wireless Home Cinema System
Basic checks first. Have you checked they are connected properly? Maybe used a different cable to check whether the rear cables are faulty? You may just have turned your system to 2.1 surrououn sound by accident or be playing a format that only supports 2.1. Check that in the system menu under dec. mode that if it is set to AFD STD that you are playing a DVD which shows can support 5.1 on the back of its cover. Also try running the setup manually and choosing your speaker configuration. Hope this helps.
SOURCE: Panasonic Wireless Rear Speakers Ticking
move ur speakers around. if the noise is absent on some places u can be sure its the digital box. or one fix that might work is - get aluminium foils and wrap ur speakers. this can blank out interferences. if that works, open ur speakers and line the walls with thick aluminium foils. hope this helps.
