Kitchen Appliances - Others Logo
Question about Galaxy Kitchen Appliances - Others
G12 operation manual - Galaxy Kitchen Appliances - Others
Posted by Sandy Rockwell on
Tim Eischens
    Champion:
  • 252 Answers
My canon powershot g12 lcd works fine but the photos are all 'whited' out
You may have the exposure compensation settings overexposing you images. Since it compensates without affecting the image prior to shooting, you won't see it until after the image is taken. Check that and the flash exposure compensation too.
All my shots from Canon G12 started to be striped.Like moire.
It might be a CCD problem.. consult doctor.. camera doctor.
Hi apart from other problems, I am unable to delete photos on my G12 - help!
If you are having other problems as you mention, quite possibly they are all effecting the operation of the camera. one problem is all that is needed to mess up a camera plus adding more makes thing even worse. sounds like the camera needs some service.
G12 manual download
You may download the G12 manual and more here.
HOW TO I GET A COPY OF MANUAL FOR MY G12
You can download copy of the user manual for this camera from this link, just click HERE and proceed with the download.
I have a 2000 reg polo i want to put water in for the enginge and it says G12 with a picture of a book and a ! inside the pick what is this? please
A new "G12" coolant additive, recognized by its red color, has been introduced during m.y. 1997, replacing the "G11" used previously.
The "G11" and "G12" coolant additives are NOT interchangeable, and must NEVER be mixed. Use only water or "G12" coolant additive G 012 A8D A1 to top up cooling systems filled with "G12" = GLYSANTIN Alu Protect/G30 silikatfrei
Once coolants stabilize and provided the system remains sealed and airtight (has not overheated where it vented) then the system should not require any flushing or changing of the coolant (specific to HOAT/G12 type coolants).
G12 after about 5,000-10,000 miles reaches that point of stability where the coolant has neutralized any reactions that may occur. As long as that stability is not thrown off, leave it alone.
In the case of the TDI the water pump requires replacement, this should be the only time that the cooling system is drained and flushed and the system refilled. sticking with G12 insures that the original balance of chemicals are maintained as close as possible to the stabilization point to eliminate any risk of system contamination or corrosion.
It's really simple, G12 out, G12 in, to insure system protection and integrity.
Need Operating Instructions
Visit
http://www.morphyrichards.co.uk/DownloadSearchResults.aspx?G1=G12
and check if there is a similar kettle to yours,
if not contact
http://www.morphyrichards.co.uk/CustomerCare.aspx
and request the manual.
Is the midland gxt 650 compatable with the g12
All type-accepted GMRS radios operate on the same frequencies and use the same type of transmissions. Channel numbers are the same on most models, but check the channel/frequency chart in the radio's operating manual to be sure.
Bill B
Top Galaxy Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
john h
Are you a Galaxy Kitchen Appliances - Other Expert? Answer questions, earn points and help others
